for (z=11;z<13;z++) // Only for the first two sensors
Wire.requestFrom(z, 4); // Get the contents of first two registers"
num = Wire.available();
Serial.print(num);
y1 = Wire.read(); // first received byte stored here
y2 = Wire.read();
x1 = Wire.read();
x2 = Wire.read();
Are your device addresses 11 and 12? Also it would be useful to test if you got 4 (in num). If the device doesn't respond, and you don't get 4 returned from Wire.available() then the reads will return rubbish.
