Ok I just posted my code. It's compatible with standard keypads library for arduino and my own version of library.
Hi! I have a problem compiling your code error says "multi_tap_threshold was not declared in this code". What should be the value of multi_tap_threshold and where should I declare it?
here's my code and I'm not sure if this is correct. I'm not good in programming though.
#include <Keypad.h>
#define RESET_MTP '~'
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
int pointer;
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {11,6,7,9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {10,12,8}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
int mtKey=0;
byte key=keypad.getKey(); // Get a key press from the keypad
mtKey=multi_tap(key); // Feed the key press to the multi_tap function.
Serial.print(mtKey);
int multi_tap(byte key)
static boolean upperCase=true;
static byte prevKeyPress=NO_KEY,cyclicPtr=0;
static unsigned long prevKeyMillis=0;
static const char multi_tap_mapping[10][5]={{'0','#','
,'.','?'},{'1','+','-','','/'},{'A','B','C','2','!'},{'D','E','F','3','%'},{'G','H','I','4','('},{'J','K','L','5',')'},{'M','N','O','6','@'},{'P','Q','R','S','7'},{'T','U','V','8',','},{'W','X','Y','Z','9'}};
if (key==RESET_MTP) // Received reset command. Flush everything and get ready for restart.
upperCase=true;
prevKeyPress=NO_KEY;
cyclicPtr=0;
return 0;
if (key!=NO_KEY) // A key is pressed at this iteration.
if ((key>'9')||(key<'0')) // Function keys
if ((key==1)||(key=='#')) // Up for case change
upperCase=!upperCase;
return 0;
else // Other function keys. These keys produce characters so they need to terminate the last keypress.
if (prevKeyPress!=NO_KEY)
char temp1=multi_tap_mapping[prevKeyPress-'0'][cyclicPtr];
if ((!upperCase)&&(temp1>='A')&&(temp1<='Z')) temp1+='a'-'A';
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
return 0; // Clear the buffer.
break;
case 3:
prevKeyPress='\b';
break;
case 4:
case '':
prevKeyPress=' ';
break;
case 5:
prevKeyPress='\n';
break;
case 6:
prevKeyPress=NO_KEY; // Clear the buffer.
break;
return(256+(unsigned int)(temp1));
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
break;
case 3:
return (256+(unsigned int)('\b'));
break;
case 4:
return (256+(unsigned int)(' '));
break;
case 5:
return (256+(unsigned int)('\n'));
break;
case 6:
break;
if (prevKeyPress==key)
char temp1;
cyclicPtr++;
if ((multi_tap_mapping[key-'0'][cyclicPtr]==0)||(cyclicPtr==5)) cyclicPtr=0; //Cycle key
prevKeyMillis=millis();
temp1=multi_tap_mapping[key-'0'][cyclicPtr];
return ((unsigned int)(temp1));
prevKeyPress=key;
cyclicPtr=0;
//Print key on cursor+1
char temp1=multi_tap_mapping[key-'0'][cyclicPtr];
prevKeyPress=key;
cyclicPtr=0;
else // No key is pressed at this iteration.
if (prevKeyPress==NO_KEY) return 0; // No key was previously pressed.
else if (millis()-prevKeyMillis<multi_tap_threshold) // Key was pressed previously but within threshold
return((unsigned int)(temp1));
else // Key was pressed previously and threshold has passed
cyclicPtr=0;
return 0;
#include <Keypad.h>
int pointer;
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
void setup(){
int mtKey=0;
upperCase=true;
cyclicPtr=0;
return 0;
return 0;
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
break;
case 3:
prevKeyPress='\b';
break;
case 4:
case '':
prevKeyPress=' ';
break;
case 5:
prevKeyPress='\n';
break;
case 6:
break;
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
char temp1;
cyclicPtr++;
prevKeyPress=key;
cyclicPtr=0;
prevKeyPress=key;
cyclicPtr=0;
cyclicPtr=0;
return 0;
brutal_magnet:
Hi! I have a problem compiling your code error says "multi_tap_threshold was not declared in this code". What should be the value of multi_tap_threshold and where should I declare it?here's my code and I'm not sure if this is correct. I'm not good in programming though.
Just do #define multi_tap_threshold 1000
This is the time the function waits until a letter is confirmed. Say you press "2" three times, and wait for 1000 ms then the letter C becomes the output. If you want a longer wait, you can increase the 1000.
Updated code:
I made changes so that you only see the real output, the C, not the temporary such as A then B then C.
The multi-tap only works well on a display, not a serial port, although you can do your preliminary test over a serial port, you can't render a character in place.
#include <Keypad.h>
int pointer;
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
void setup(){
int mtKey=0;
if(!(mtKey&10000000B)) Serial.print(mtKey);
upperCase=true;
cyclicPtr=0;
return 0;
return 0;
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
break;
case 3:
prevKeyPress='\b';
break;
case 4:
case '':
prevKeyPress=' ';
break;
case 5:
prevKeyPress='\n';
break;
case 6:
break;
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
char temp1;
cyclicPtr++;
prevKeyPress=key;
cyclicPtr=0;
prevKeyPress=key;
cyclicPtr=0;
cyclicPtr=0;
return 0;
Hi! Well as for the code that you updated, it doesn't compile "error: invalid suffix 'B' on integer constant". I tried removing the 'B' on the if (!mtkey&10000000B) which becomes if (!mtkey&10000000), it compiles but no output..
And may I ask, how can I store the input from the keypad? By the way I'm using 4x3 keypad. Say I entered, '1' then 'a' then 'b', those letters will be saved and stored to char output[4] so if I do lcd.print(output), it will display '1ab'. Thank you!
Typo. Should be B10000000.
You should read these lines at the beginning of my code before you started, especially step 3:
Also, remapping your 'A' key into '#' key will make it into upper/lower case function.
This portion of code is the multi-tap function written by Dr. John Liu. It is provided to you without any warranty. Your use is limited to not-for-profit activities.
You may change the definition of the multi-tap keypad, which contains 5 symbols per numerical key for all 10 numerical keys.
To use the function:
- Call your keypad's getKey method to receive a key. This key has to be '0' to '9' or other symbols such as '#' or NO_KEY or scan codes for phi_keypads objects.
- Call multi_tap and pass the received key to it.
- The returned value indicates what is going on.
If the most significant bit (MSB) is set to 1, then the multi-tap is in process. You should print the return value (with MSB reset to 0) in place.
If MSB is reset to 0, then the multi-tap has concluded and a final character is produced. You should print this character in place and move cursor to the next position.
If the return value is NO-KEY, then nothing is happening.
Pressing the '#' key engages or disengages shift to switch between upper and lower cases.
Calling the multi_tap with RESET_MTP will result in the multi_tap process to reset, useful if you are unsure of the function's status. Say you didn't finish a multi-tap process and switch to another piece of code and then later want to use multi-tap, you should reset it before using. The return value for this call is to be discarded.
HI liudr,
your layout of the multitap resembles the layout ot letters on mobile phones which is/was be patented. might be a point of attention if it still is (or some variation)
There are some differences though on your custom pad e.g. the 2x5 layout.
Thanks Rob. I will look into it. Here is something I found:
http://www.itu.int/rec/dologin_pub.asp?lang=e&id=T-REC-E.161-200102-I!!PDF-E&type=items
There is no patent on it.
hi! can you help me with my 4x3 keypad matrix? I want it to do the same thing as your phi-panel but I just don;t know how..TIA!
When you tried this code, what did you see? You got to give me something (symptoms) to get help:
Plus, as I said, using multi-tap on serial monitor is not good since serial monitor can't render a character in place. You should use serial monitor for trying it out and use an LCD for serious results.
#include <Keypad.h>
int pointer;
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
void setup(){
int mtKey=0;
if(!(mtKey&B10000000)) Serial.print(mtKey);
upperCase=true;
cyclicPtr=0;
return 0;
return 0;
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
break;
case 3:
prevKeyPress='\b';
break;
case 4:
case '':
prevKeyPress=' ';
break;
case 5:
prevKeyPress='\n';
break;
case 6:
break;
cyclicPtr=0;
prevKeyMillis=0;
switch (key)
case 2:
// Call symbol list
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
char temp1;
cyclicPtr++;
prevKeyPress=key;
cyclicPtr=0;
prevKeyPress=key;
cyclicPtr=0;
cyclicPtr=0;
return 0;
Whenever I tried to open the Serial Monitor I only get never ending 0's. And also I'm thinking about displaying it on LCD too so maybe I should only replace Serial.begin(9600) with lcd.begin(16,2) and Serial.print(mtKey) with lcd.print(mtKey)??
Since you can re-locate your LCD cursor, you want to think about that, lcd.serCursor(0,0); lcd.print()
Try this mod:
into
if((!(mtKey&B10000000))&&(mtKey!=0)) Serial.print((char)mtKey);
I will check the code when I have some time tonight.
This code can now display the character but keeps on looping until I added some condition and turns the above code to this
if((!(mtKey&B10000000))&&(mtKey!=0) && key!=NO_KEY)
and voila! It is now working fine!!!
Sorry for being sloppy. I didn't have the software or hardware in front of me and forgot the NO_KEY is NOT 0. My bad. Now you can transfer it to an LCD, hold the cursor position if the user is still cycling through the choices and only advance cursor if the user decides (could be tricky). My original reply with the instruction should help.
BTW, if you're interested at all in supporting all my free codes and libraries, take a look at the products I made with these codes, especially the panels
I'm going to try it out on LCD tomorrow, need to take a rest now.. btw cool stuff you got there!
The original keypad is kind of small, with only 5 symbols per number key. I recently expanded to 7 symbols per key to cover all printable ASCII. I'll post the code once I'm ready.
So what kind of project do you have in mind for multi-tap?
Hello,
So I'm trying to implement this code but for some reason every time i "multi tap" it prints all of the characters to the LCD instead of juts the last one,
Also, sometimes, when i press another button, it reprints the output of the previous button instead of the new one
What am I doing wrong?
Thank you!
foobar:
Hello,So I'm trying to implement this code but for some reason every time i "multi tap" it prints all of the characters to the LCD instead of juts the last one,
Also, sometimes, when i press another button, it reprints the output of the previous button instead of the new oneWhat am I doing wrong?
Thank you!
Have you run the sample code? Where is your code? And video? You know, you need to hold the LCD cursor in place when rendering the intermediate choices just like on a cell phone, printing out all characters is required, don't you think?
Hey!
Thank you for your quick response! and sorry I wasn't quick in responding back for some reason I didn't get any notification of your response!
Anyways,
I have been running the sample code actually, I can upload a video later tomorrow if you need that,
but actually you're right that I haven't been holding the LCD cursor in place, where in the code should I do that though to ensure that it works properly ?
Thank you :)!
The code is just the function and there is no rendering in the function. I don't have my phi-panel firmware at hand to cut paste you my code but essentially you keep calling your keypad.getKey() and supply the return value to multitap(). Then if you see the multitap returns a value that is above 127 (it's all in the code comments) you print the return, stripping MSB, in place holding the cursor (serial monitor can't do that so only LCD can). If return is less than 127, you print it and let the cursor move by itself. Think about how multitap is done on a phone screen.
