No, I can't find the hex file. I found this link http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1287332515 but holding the shift key down activates the Upload with programmer action now. Any ideas on how to find the hex file? There is no verbose word or setting in the preferences.txt file of 1.0 RC2.
Also, I noticed that if there is a .pde file in the same directory as the .ino file, the compiler tries to compile them both, and gives the errors below.
In file included from OLED.cpp:529:
/font8.h:3: error: redefinition of 'const unsigned char font [][7]'
/font8.h:3: error: 'const unsigned char font [98][7]' previously defined here
In file included from OLED.cpp:530:
bitmaps.h:2: error: redefinition of 'const unsigned char usb_logo [14][10]'
bitmaps.h:2: error: 'const unsigned char usb_logo [14][10]' previously defined here
bitmaps.h:21: error: redefinition of 'const unsigned char laser_label [52][128]'
bitmaps.h:21: error: 'const unsigned char laser_label [52][128]' previously defined here
In file included from OLED.cpp:532:
arduino1.h:2: error: redefinition of 'const unsigned char arduino1 [57][60]'
arduino1.h:2: error: 'const unsigned char arduino1 [57][60]' previously defined here
OLED:504: error: redefinition of 'const int EPin'
OLED:13: error: 'const int EPin' previously defined here
OLED:505: error: redefinition of 'const int RwPin'
OLED:14: error: 'const int RwPin' previously defined here
OLED:506: error: redefinition of 'const int DCPin'
OLED:15: error: 'const int DCPin' previously defined here
OLED:507: error: redefinition of 'const int CsPin'
OLED:16: error: 'const int CsPin' previously defined here
OLED:508: error: redefinition of 'const int Enable12VPin'
OLED:17: error: 'const int Enable12VPin' previously defined here
OLED:509: error: redefinition of 'const int OLEDRstPin'
OLED:18: error: 'const int OLEDRstPin' previously defined here
OLED:511: error: redefinition of 'const int switch1'
OLED:20: error: 'const int switch1' previously defined here
OLED:512: error: redefinition of 'const int switch2'
OLED:21: error: 'const int switch2' previously defined here
OLED:513: error: redefinition of 'const int switch3'
OLED:22: error: 'const int switch3' previously defined here
OLED:514: error: redefinition of 'const int switch4'
OLED:23: error: 'const int switch4' previously defined here
OLED:516: error: redefinition of 'int bgrnd_color'
OLED:25: error: 'int bgrnd_color' previously defined here
OLED:517: error: redefinition of 'int display'
OLED:26: error: 'int display' previously defined here
OLED:518: error: redefinition of 'int font_color'
OLED:27: error: 'int font_color' previously defined here
OLED:520: error: redefinition of 'char* s_disp []'
OLED:29: error: 'char* s_disp [5]' previously defined here
OLED.cpp: In function 'void setup()':
OLED:523: error: redefinition of 'void setup()'
OLED:32: error: 'void setup()' previously defined here
OLED.cpp: In function 'void loop()':
OLED:540: error: redefinition of 'void loop()'
OLED:49: error: 'void loop()' previously defined here
OLED.cpp: In function 'void command(int)':
OLED:574: error: redefinition of 'void command(int)'
OLED:83: error: 'void command(int)' previously defined here
OLED.cpp: In function 'void data(int)':
OLED:594: error: redefinition of 'void data(int)'
OLED:103: error: 'void data(int)' previously defined here
OLED.cpp: In function 'void init_colorlcd(int)':
OLED:613: error: redefinition of 'void init_colorlcd(int)'
OLED:122: error: 'void init_colorlcd(int)' previously defined here
OLED.cpp: In function 'void gotoxy(int, int)':
OLED:701: error: redefinition of 'void gotoxy(int, int)'
OLED:210: error: 'void gotoxy(int, int)' previously defined here
OLED.cpp: In function 'void set_screen(int)':
OLED:724: error: redefinition of 'void set_screen(int)'
OLED:233: error: 'void set_screen(int)' previously defined here
OLED.cpp: In function 'void clear_screen()':
OLED:754: error: redefinition of 'void clear_screen()'
OLED:263: error: 'void clear_screen()' previously defined here
OLED.cpp: At global scope:
OLED:759: error: redefinition of 'const int amask [16]'
OLED:268: error: 'const int amask [16]' previously defined here
OLED:760: error: redefinition of 'const byte mask [6]'
OLED:269: error: 'const byte mask [6]' previously defined here
OLED.cpp: In function 'void xyputs(unsigned char, unsigned char, int, int, char*)':
OLED:762: error: redefinition of 'void xyputs(unsigned char, unsigned char, int, int, char*)'
OLED:271: error: 'void xyputs(unsigned char, unsigned char, int, int, char*)' previously defined here
OLED.cpp: In function 'void puts8(int, int, char*)':
OLED:833: error: redefinition of 'void puts8(int, int, char*)'
OLED:342: error: 'void puts8(int, int, char*)' previously defined here
OLED.cpp: In function 'void draw_line(unsigned char, unsigned char, unsigned char, unsigned char, int)':
OLED:839: error: redefinition of 'void draw_line(unsigned char, unsigned char, unsigned char, unsigned char, int)'
OLED:348: error: 'void draw_line(unsigned char, unsigned char, unsigned char, unsigned char, int)' previously defined here
OLED.cpp: In function 'void draw_rectangle(unsigned char, unsigned char, unsigned char, unsigned char, int, int)':
OLED:861: error: redefinition of 'void draw_rectangle(unsigned char, unsigned char, unsigned char, unsigned char, int, int)'
OLED:370: error: 'void draw_rectangle(unsigned char, unsigned char, unsigned char, unsigned char, int, int)' previously defined here
OLED.cpp: In function 'void draw_circle(unsigned char, unsigned char, unsigned char, int, int)':
OLED:883: error: redefinition of 'void draw_circle(unsigned char, unsigned char, unsigned char, int, int)'
OLED:392: error: 'void draw_circle(unsigned char, unsigned char, unsigned char, int, int)' previously defined here
OLED.cpp: In function 'void enable_fill(unsigned char)':
OLED:902: error: redefinition of 'void enable_fill(unsigned char)'
OLED:411: error: 'void enable_fill(unsigned char)' previously defined here
OLED.cpp: In function 'void do_picture(int, int, int, int, const unsigned char*)':
OLED:941: error: redefinition of 'void do_picture(int, int, int, int, const unsigned char*)'
OLED:450: error: 'void do_picture(int, int, int, int, const unsigned char*)' previously defined here
