I have a Cold Tears 3.5 inch 480x320 R61581 with a ADS7843 compatible touch controller running on a CTE Due LCD Shield connected to arduino DUE. I'm using Cold Tears modify version of the Hennings UTFT and UTouch Libraries.
#include "SPI.h"
#include <UTFT.h>
#include <UTouch.h>
#define FLASH_CS_PIN 52
#define SPI_RATE 2
//Font selection
//BVS= Bitstream vera sans, suffix = font size in pixel (height)
#define BVS_13 10
#define BVS_15 12
#define BVS_19 14
#define BVS_22 18
#define BVS_28 22
#define BVS_34 28
#define BVS_43 38
#define BVS_52 53
#define BVS_74 78
#define BVS_112 122
extern uint8_t SmallFont[];
UTFT myGLCD(CTE35); // Remember to change the model parameter to suit your display module!
UTouch myTouch(6,5,32,3,2);
myGLCD.SPI_Flash_init(FLASH_CS_PIN,SPI_RATE);
Serial1.begin(38400);
myGLCD.InitLCD();
myTouch.InitTouch();
myGLCD.setFont(SmallFont);
myGLCD.clrScr();
myGLCD.Swtich_LCD_TB_Bit(0);
myGLCD.Load_image(0,0,664);
myGLCD.setColor(0,0,0);
myGLCD.setBackColor(130,192,229);
myGLCD.Put_Text("Sonora Technical",320,5,BVS_22);
myGLCD.drawRect(10,10,50,50);
long x, y;
myTouch.read();
x = myTouch.getX();
y = myTouch.getY();
while (true) {};
What I'm seeing are the coordinates are turn 180 degrees. My text is not upside down and is not reversed but my cordinates appear to start at the right hand corner. Ok, If I rotate the screen 180 degress...then my bitmap will be rotated 180deg, and the text will be upside down and backwards...however it will start at the correct coordinates.
I am having the same problem on the 3.2". Daniel and I are teaming up to work on this issue together. We have the same shields, LCDs, DUEs...and unfortunately..the same exact issues...
Very frustrating to purchase products, download their demos, their libraries... then run them and the images are flipped, mirrored, rotated 180 deg. text is mirrored...bitmaps are not... etc.. etc... touchscreen counts down backwards, etc...
Is there anyone using these 3.2" and 3.5" ColdTears products where they just work?
Trying to determine if Daniel and I have a bad batch (we ordered them together).
I have a similar problem with a 7" display from CTE, "DUE shield + CTE70". All the UTFT fonts and coordinates are mirrored.
However the 7" display came with custom fonts on rom and they display correctly. But they do not work with the set font functions. This means that the printnumI in the printnumF does not work or will not be readable if I use the UTFT fonts.
Does anyone else have this problem, And has anyone found a solution.
ODwyerPW:
coldtears didn't help. i solved the problem buy adding screen reverse code i found in utft_due libraly which coldtears gives. and for use touch panel in correct way, i use orginal utocuh libraly and upload calibration sketch. there is no problem now.
I purchased hte 3.5" model from coldtears. I rewrote the library to get it all to work and to work in PORTRAIT mode.
I forwared the code to coldtears, they returned an email saying they rewrote there code and it all works now.
So I would hit them up again and see if they have updated librarys for your display.
Unfortunately the different sizes use different chip sets for the code isn't interchagable, the library has a huge case statement that looks thru all the displays.
I'm not really a fan of having all displays loaded when I only need one, also if you make a change you really should check the functionallity of all the other supported displays. Uh let's see I think I'll make a change to my universal driver that i'm using to add a feature to the display I'm using, ok the change is made ok now all i have to do is get out the 30 different displays download the new code and test all 50 functions on each 30 displays and make sure I test all possible orders of functions on each display hmmmmm( 30 displays * 50 functions * (modes (landscape and portrait) uh no thanks I'll keep the libraries seperate one for each display.
Thats the way we do it now when you load a library for a RTC it doesnt contain every sensor/gizmo possible, only the RTC.
Cold tears sent me a link that didn't work, when I get a good one I'll post it here, if needed I can post the code I have for my CTE 3.5.
We'd love to see that code. Daniel and I each have the DUEs, CTE Shields and CTE LCDs (the 3.5, the 5 and the 7).
We are working independently and sometimes together on these issues. (Lately, I've played more with the MiniPro and have enjoyed the simplicity very much, but eventually I will get back to DUE and these LCDs).
Daniel's been focused on the 3.5... hence this thread.
I have more interest in the 5", but will use the 3.5" in my application if it proves easier to use.
I agree with your assessment... Daniel and I have talked about eliminating ALL of the other stuff except the 3.5 and 5 that we are using just to decrease the size of the libraries....both for the LCD and the Touch.
Ive got this problem on a 7 inch screen. But the myGLCD.Switch_LCD_TB_Bit(1); command is not recognized in the UTFT library (latest update from Hennings site)
Does anyone know the right command to reverse the mirrored image? Its got me stumped.!
ODwyerPW:
I had a CTE35IPS on loan a little while ago, with the latest version of UTFT (V2.81) and a CTE shield, it worked absolutely fine in terms of orientation, and touch functionality, what did not work fine was the font ic. But all of the UTFT functions were ok without any modification.
I've come up with a solution as I had the same problem myself. Basically, take the overall dimension of your display (mine is 480 x 272) and subtract the relevant x and y dimensions from the overall dimension to give an inverted figure. Its not the BEST answer to the problem, but it works for me! ;D
