After I worked in my first Arduino programs, maybe because I worked for a good time with languages like Java and C#, I have found that is a job a little outdated. Tasks like to handle push of buttons or turn a LED on smoothly through PWM, although of being easy to understand, require a reasonable volume of code to become consistent, especially when is necessary that various components work simultaneously.
Because I suffer with this problem that I decided to turn all my difficulties in Arduino programming in a collection of classes that assist the programmer. Currently this collection includes the following components:
AnalogEvent
Event handler for analog ports that can be used to read potentiometers or others sensors. Implements the event onChange.
In this example we configure the analog pin 1 to read values from a potentiometer with an hysteresis value of 3:
#include <AnalogEvent.h>
AnalogEvent.addAnalogPort(1, //potentiometer pin
onChange, //onChange event function
3); //hysteresis
AnalogEvent.loop();
void onChange(AnalogPortInformation* Sender) {
Serial.print("Analog (pin:");
Serial.print(Sender->pin);
Serial.print(") changed to: ");
Serial.print(Sender->value);
Serial.println("!");
ButtonEvent
Event handler for buttons (tactile switches) on digital ports. Implements the events onUp, onDown, onHold and onDouble.
In this example we configure the pin 12 as a button with all events enabled:
#include <ButtonEvent.h>
ButtonEvent.addButton(12, //button pin
onDown, //onDown event function
onUp, //onUp event function
onHold, //onHold event function
1000, //hold time in milliseconds
onDouble, //double event function
200); //double time interval
ButtonEvent.loop();
void onDown(ButtonInformation* Sender) {
Serial.print("Button (pin:");
Serial.println(") down!");
void onUp(ButtonInformation* Sender) {
Serial.println(") up!");
void onHold(ButtonInformation* Sender) {
Serial.print(") hold for ");
Serial.print(Sender->holdMillis);
Serial.println("ms!");
void onDouble(ButtonInformation* Sender) {
Serial.print(") double click in ");
Serial.print(Sender->doubleMillis);
LedControl
Simple LED functions with asynchronous capabilities. Permits turning on, off and dimmer.
In this example two LEDs blinking together in different manners. The LED in pin 9 is configured to 500ms of fade in/out with 1s of interval, and the LED at pin 8 is a simple blinker with 200ms of interval:
#include <LedControl.h>
LedControl.startBlink(9,1000,500);
LedControl.startBlink(8,200);
LedControl.loop();
This project has their own repository with more information about the classes, usage instructions and download options. The project name is ebl-arduino, that means Event-Based Library for Arduino, and your page could be accessed through the URL GitHub - renatoferreirarenatoferreira/ebl-arduino: Automatically exported from code.google.com/p/ebl-arduino.
Source: Event-Based Library for Arduino
