Topic: Arduino Avrdude Troubleshooting. (Read 755 times) previous topic - next topic
Arduino99
i found out recently that avrdude is having trouble communicating with my arduino mega and uno when using them as a ICSP/ISP Programmer. i dont know what happens but when i run avrdude in the command prompt i keep getting this error.
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
spycatcher2k
What code do you have on the mega and uno?
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
Arduino99
Nothing, this is trying to burn bootloader to an external 16l8pu.
spycatcher2k
Upload the Arduino as ISP sketch, then change the programmer to Arduino as ISP, then upload the bootloader to the external unit.
Mrs Drew
Arduino99
Avrdude is now picking up my arduino's but is still spitting out errors.
         Using Port                    : COM5
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
spycatcher2k
Can you tell us your wiring, exactly as you have it.  :)
Mrs Drew
Arduino99
im not wiring anything, im trying to get avr dude to work correctly before i even think of doing anything, i uploaded the arduino as isp sketch to both my uno and mega and i get the errors on both
spycatcher2k
Then the error you have is correct, it cannot read anything connected to the programmer!
Mrs Drew
Arduino99
#8
Aug 12, 2017, 10:31 pm Last Edit: Aug 12, 2017, 10:45 pm by Arduino99
right! okay then, so now avrdude is working correctly, how do i go about uploading the bootloader to the 16l8pu?
Edit: I cant burn the bootloader because of this error! So im stuck again
spycatcher2k
I've never heard of a 16I8pu! so can't comment, but if you google it i'm sure the solution will present itself.  :)
Mrs Drew
Arduino99
#10
Aug 12, 2017, 10:53 pm Last Edit: Aug 12, 2017, 11:01 pm by Arduino99
This!
Atmel ATMEGA16L-8PU
http://www.atmel.com/Images/2466S.pdf
something is not right at all now, i cant do anything while that error persists!
Arduino99
Something is no right with AVRdude, i just attacthed my nano(which has been sitting for ages) and i still get the same error.
spycatcher2k
No- somthing no right with your wiring, bus as you have not shown any, NO ONE CAN HELP!
Mrs Drew
Arduino99
#13
Aug 12, 2017, 11:25 pm Last Edit: Aug 12, 2017, 11:31 pm by Arduino99
Apologies for the last post...
just getting pretty annoyed that it just refuses to work.
heres the setup
https://www.dropbox.com/s/ds87ibe7sal8r4r/IMG_20170812_222854.jpg?dl=0
spycatcher2k
BECAUSE THERE IS NO WIRING!
Then you will get errors!!
Twat!
Mrs Drew
