Hello.
I'm trying to create an airsoft pellet counter with two seven segment displays. For detecting pellets I used a phototransistor (KTS-AME s.r.o. | Prodej náhradních dílů pro spotřební elektroniku, dálkové ovladače | KTS-AME s.r.o.) and a bright red LED which created a gate at the end of muzzle. The sensor's analog value is around ~30 when the led emits light and 1023 when there's an object blocking the light. Everything works perfectly but the sensor doesn't register a pellet traveling 110m/s. It does register a pen though. The diameter of a pellet is 6mm. I used this code:
const int A = 6;
const int B = 7;
const int C = 8;
const int D = 9;
const int E = 10;
const int F = 11;
const int G = 12;
const int mltx_pin = 5;
const int sensor_pin = A0;
boolean mltx_val = true;
boolean tick = true;
int count = 68;
int cycle = 0;
int zero_blink = 0;
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(E, OUTPUT);
pinMode(F, OUTPUT);
pinMode(G, OUTPUT);
pinMode(mltx_pin, OUTPUT);
void mltx_reverse()
if (mltx_val==false)
{mltx_val=true;}
{mltx_val=false;}
void no_blank()
digitalWrite(A, HIGH);
digitalWrite(B, HIGH);
digitalWrite(C, HIGH);
digitalWrite(D, HIGH);
digitalWrite(E, HIGH);
digitalWrite(F, HIGH);
digitalWrite(G, HIGH);
void no_0()
digitalWrite(A, LOW);
digitalWrite(B, LOW);
digitalWrite(C, LOW);
digitalWrite(D, LOW);
digitalWrite(E, LOW);
digitalWrite(F, LOW);
void no_1()
void no_2()
digitalWrite(G, LOW);
void no_3()
void no_4()
void no_5()
void no_6()
void no_7()
void no_8()
void no_9()
//CONTROL MULTIPLEX
if (mltx_val==true)
digitalWrite(mltx_pin, LOW);
digitalWrite(mltx_pin, HIGH);
//RESET COUNTER
if (count<0)
count=68;
//READ SENSOR
int sensor_value=analogRead(sensor_pin);
if (tick==false)
if (sensor_value<100)
tick=true;
count-=1;
if (sensor_value>150)
tick=false;
Serial.print("sensor_value = ");
Serial.print(sensor_value);
Serial.print("\t count = ");
Serial.print(count);
Serial.print("\t tick = ");
Serial.println(tick);
if (zero_blink<500)
if (cycle==0)
//DO STUFF
if (mltx_val==true)
//DRAW ONES
int val=floor(count/10);
if (val==0) {no_0();}
if (val==1) {no_1();}
if (val==2) {no_2();}
if (val==3) {no_3();}
if (val==4) {no_4();}
if (val==5) {no_5();}
if (val==6) {no_6();}
if (val==7) {no_7();}
if (val==8) {no_8();}
if (val==9) {no_9();}
//DRAW TENS
int val=count-(floor(count/10)*10);
no_blank();
no_blank();
zero_blink+=1;
if (zero_blink>1000 || count>9)
zero_blink=0;
cycle+=1;
if (cycle>2)
cycle=0;
mltx_reverse();
The code does 10000 cycles in about 6 seconds which is 0.6ms per cycle. A pellet travels 110mm/ms which means for each cycle the pellet travels 66mm. I even simplified the code to this:
const int analogInPin = A0;
int counter = 0;
boolean tick = false;
int sensorValue = analogRead(analogInPin);
if (tick==false)
if (sensorValue<250)
tick=true;
counter+=1;
if (sensorValue>280)
tick=false;
Serial.print("sensor = ");
Serial.print(sensorValue);
Serial.print("\t counter = ");
Serial.print(counter);
Same result. What should I do? I have Arduino Micro.
