/******* Sketch to test Input Capture interrupt handling *********************************
functionality: measure length of pulses on the ICP pin with precision of 0.5 microseconds
Show the min and max pulse widths in microseconds on the serial port
#include <stdio.h> // for verbose debugging using sprintf
//#include "TimerOne.h"
//#include "Timer.h"
#include "PWM.h"
#define icpPin 8 // ICP input pin on arduino
//#define outPin 9 // output pin that will shadow the input, can be monitored with a scope
#define outPin 9
volatile uint8_t rising;
// some variables to help see that something is happening in the interrupt handlers
volatile unsigned int Value; // this stores the current ICR1 value
volatile unsigned int MinValue;
volatile unsigned int MaxValue;
volatile unsigned int Overflows;
volatile unsigned int PulseCount;
unsigned long duration;
//int32_t frequency = 125000
char buffer[800];
short i;
//Timer t;
/* Overflow interrupt vector */
ISR(TIMER2_OVF_vect){ // here if no input pulse detected
Overflows++; // incriment overflow count
/* ICR interrupt vector */
ISR(TIMER2_CAPT_vect){
TCNT1 = 0; // reset the counter
catchRisingEdge();
/*if( bit_is_set(TCCR1B ,ICES1)){ // was rising edge detected ?
digitalWrite(outPin,HIGH ); // yes, set our output pin high to mirror the input
else { // falling edge was detected
Value = ICR1; // save the input capture value
digitalWrite(outPin,LOW ); // set our output pin low to mirror the input
PulseCount++;
}/*if(Value < MinValue) // update min or max values as appropriate
MinValue = Value;
if (Value > MaxValue)
MaxValue = Value;
TCCR1B ^= (1<<ICES1); // toggle bit value to trigger on the other edge
/*if(bit_is_set(TCCR1B, ICES1)){
digitalWrite(OUT, HIGH);
else{
Value = ICR1;
digitalWrite(OUT, LOW);
PulseCount++;
/* static byte lastEdge;
byte thisEdge = ICR1;
byte difference = lastEdge - thisEdge;
if (difference
lastEdge = thisEdge; */
/*ISR(TIMER0_COMPA_vect){
if(i<800){
buffer[i] = digitalRead(icpPin);
}i++;
//int val = 0;
//int ledPin = 11;
//int analogPin = 3;
//int pwmPin = 9;
//const int16_t TOGGLE_TIME = 8;
//pinMode(outPin, OUTPUT); // declare the ledPin as an OUTPUT
//pinMode(icpPin, INPUT); // ICP pin (digital pin 8 on arduino) as input
//MinValue = 30000; // Initialise with extreme values
//MaxValue = 0;
//SetPinFrequency(9, 125000);
pinMode(9, OUTPUT);//125kHz carrier to be generated here
//Timer1.initialize(8);
//Timer1.pwm(9, 512);
/*digitalWrite(9, HIGH);
delayMicroseconds(8);
digitalWrite(9, LOW);
delayMicroseconds(8);*/
//USE FAST MODE TO ENABLE DOUBLE BUFFERING - GIVES A GLITCH FREE OUTPUT
//TCCR1A |= (0<<COM1A1)|(1<<COM1A0) ; //Toggle on reaching OCRA // this register set to 0!
//TCCR1A |= (1<<WGM10);
TCCR1A |= (1<<COM1A1)|(1<<COM1A0)|(1<<COM1B1)|(1<<COM1B0)|(1<<WGM11)|(1<<WGM10);
TCCR1B |= (1<<ICNC1)|(1<<WGM13)|(1<<WGM12)|(1<<CS11); //prescaler 8 //SET TO Fast PWM MODE // NORMAL MODE!!, prescaler 8, rising edge ICP1 - this works
// enable input capture
OCR1A = 127;
OCR1B = 63;
TIMSK1 |= (1<<ICIE1)|(1<<TOIE1); // enable input capture interrupt for timer// enable overflow interrupt to detect missing input pulses
TCCR2A |= (1<<WGM21);
TCCR2B |= (1<<CS22)|(1<<CS21);
OCR2A = 1;
TCCR0A |= (1<<WGM01);
TCCR0B |= (1<<CS02) | (1<<CS00);
OCR0A = 1;*/
Serial.print("Finished setup\r\n");
//duration = pulseIn(9,HIGH);
//Serial.println(duration);
//t.start(8);
//t.pwm(9,512);
//t.pulse(9, 0.008, LOW);
//t.oscillate(9,0.008,LOW);
//t.every(4, takeReading);
//t.oscillate(9,8, LOW);
//delayMicroseconds(8);
//t.oscillate(9,8, HIGH);
//t.every(4000000, takeReading);
// Turn the frequency on
void on()
TCNT1H = 0;
TCNT1L = 0;
TCCR1A |= (1 << COM1A0);
// Turn the frequency off and turn of the IR LED
void off()
TCCR1A &= ~(1 << COM1A0);
long lastTime;
int dataState = 0;
void catchRisingEdge() {TCCR1B |= (1<<ICES1); TIFR1 |= (1<<ICF1); rising = 1;}
void catchFallingEdge() {TCCR1B &= ~(1<<ICES1); TIFR1 |= (1<<ICF1); rising = 0;}
// this loop prints the number of pulses in the last second, showing min and max pulse widths
//char buffer[800];
// show the captured data, divide pulse widths by 2 to display time in microseconds
//sprintf(buffer,"Got %d pulses: min=%d, max=%d (%d timer overflows)\r\n", PulseCount, MinValue / 2, MaxValue / 2, Overflows);
//on();
// digitalWrite(OUT, HIGH);
// delay(8);
// digitalWrite(OUT, LOW);
// delay(8);
//off();
//int val = digitalRead(9);
/*uint8_t state = 0;
while(1) {
if(state == 0) {
state = 1;
delay(8);
catchRisingEdge();
//Serial.println(state);
//Serial.println(rising);
else {
state = 0;
delay(8);
catchFallingEdge();
//duration = pulseInLong(9, HIGH);
//value = pulseIn(9, HIGH);
int analogValue = analogRead(9);
int newdataState = (analogValue > 600);//need to check, hoping boolean will evaluate to 1 when true
if(dataState == 0 && newdataState == 1){//if the led was off, but will be turned on, start the stop watch
lastTime = millis();//store the current time
dataState = newdataState;
if(dataState == 1 && newdataState == 0){//if the led was on, but will be turned off, get the difference between the last time we started counting time
long difference = millis() - lastTime; //get the current time, but subtract the last stored time
Serial.println(difference);
digitalWrite(9,dataState);*/
while(1){
if
/*static uint16_t last_toggle;
if ((uint16_t) micros() - last_toggle >= TOGGLE_TIME) {
PINB = _BV(PB1); // invert pin state
last_toggle += TOGGLE_TIME;
Serial.println(last_toggle); */
//Serial.println(val);
//val = analogRead(pwmPin);
//analogWrite(ledPin, val/4);
//Serial.print(buffer); // send the info to the serial port
/* reset variables ready for the next reading */
/*PulseCount = Overflows = 0; // reset counts
MinValue = 30000; // set values to extremes
MaxValue = 0;
delay(800); */ // wait 1 second for next update [/font]
void takeReading(){
val++;
west, I changed the settings as directed but all I get on the Serial monitor is trash values. Not sure if I y algorithm is right. Could you take a look? Most of it is commented as I have been working on the same code.
Best,
A
