system
February 27, 2009, 10:27pm
1
Hello,
i have the Arduino board for a while but evrytime I try to
compile a sketch this error message is shown:
Couldn't determine program size: C:\Dokumente und Einstellungen\Festblatte\Desktop\arduino-0013\hardware/tools/avr/bin/avr-size: 'C:\DOKUME~1\FESTBL~1\LOKALE~1\Temp\build52050.tmp\Blink.hex': No such file
It also occur when I try to compile the example sketches
Can someone help me?
Thanks and Goodbye
system
February 28, 2009, 11:34am
2
Ill be the first to ask:
Have you had this working in the past?
Which Arduino board.
Which version of the ide.
What operating system on your pc.
Have you selected the correct board.
Have you selected the right usb port ot serial port.
Have you gone through the getting started instructions.
Gordon
system
February 28, 2009, 2:08pm
3
Yes i have had this working in the past since I have the arduino.
I have the Arduino Diecimila.
I´d tried it with ide version 10 - 13.
My operation system is Windows XP Home edition SP3.
I have selected the correct board and the correct Usb port
I hope someone can help me.
Festblatte
mellis
March 3, 2009, 10:27am
4
[split] [splithere] [splithere_end]
mellis
March 3, 2009, 10:29am
5
Festblatte: do you get any other messages when you try to compile a sketch?
system
March 3, 2009, 7:07pm
6
mellis: No I only get the message form above
system
March 7, 2009, 6:12pm
7
is nobody there who have an idea how to fix this problem?
system
March 9, 2009, 7:58am
8
Try moving the files closer to C:\ drive and make sure app is running as admin, board is installed correctly and is right com port..
system
March 9, 2009, 1:12pm
9
I moved the files as close as possible to the C: and
the app is running as admin, but it doesn't help
anything.
I think its not a porblem with avr-size.exe
I think the problem is a bug in Arduino software.
Festblate
mem
March 9, 2009, 1:35pm
10
Why do you think that?
If it no longer works with earlier Arduino versions that used to work, something has probably changed in your environment that has stopped it working.
system
March 9, 2009, 1:56pm
11
I have Problems with my JRE.
I only haver JRE 1.6 because i can not install newer versions
Can it have somethig to do with this?
Festblatte
mem
March 9, 2009, 2:11pm
12
I run java build 1.6.0_11 on XP Pro SP3 without problem.
Perhaps look at the windows event view to see if you are getting any warnings or errors that could give a clue as to what is happening.
system
March 9, 2009, 3:08pm
14
The only problem is that Arduino always delete the build52050.tmp
directory when its closed because this directory is in the directory
for the temporary files.
Festblatte
If you set build.verbose=true in the Arduino IDE preferences.txt file then it should show you more what's going on and give a clue how to fix it.
Andrew
system
March 9, 2009, 4:16pm
16
I've followed the advise from Andrew. Now this is shown when i try
to compile:
C:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -IC:\arduino-0013\hardware\cores\arduino C:\arduino-0013\hardware\cores\arduino\pins_arduino.c -oC:\DOKUME~1\FESTBL~1\LOKALE~1\Temp\build51871.tmp\pins_arduino.c.o
Couldn't determine program size: C:\arduino-0013\hardware/tools/avr/bin/avr-size: 'C:\DOKUME~1\FESTBL~1\LOKALE~1\Temp\build51871.tmp\Blink.hex': No such file
I dont really know what to do with this. Perhaps anybody other know
now what to do
Festlatte
From what I understand, your Arduino IDE generates the hex file in a temp folder?
Why don't you try to save the loaded sketch first (yes, right after you loaded it). On my machine (I use Arduino 011), it defaults to "Desktop/MyDocuments/Arduino". That is where the hex file gets created.
system
March 9, 2009, 8:10pm
18
Thanks florinc for your tip but it doesnt help.
The same error message from above occures
Festblatte
When I compile "Blink" I get this lot before it tries to determine the program size. Are you sure there aren't any other messages?
Andrew
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\pins_arduino.c -oD:\arduino-0013\examples\Digital\Blink\applet\pins_arduino.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\WInterrupts.c -oD:\arduino-0013\examples\Digital\Blink\applet\WInterrupts.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\wiring.c -oD:\arduino-0013\examples\Digital\Blink\applet\wiring.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\wiring_analog.c -oD:\arduino-0013\examples\Digital\Blink\applet\wiring_analog.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\wiring_digital.c -oD:\arduino-0013\examples\Digital\Blink\applet\wiring_digital.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\wiring_pulse.c -oD:\arduino-0013\examples\Digital\Blink\applet\wiring_pulse.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\wiring_serial.c -oD:\arduino-0013\examples\Digital\Blink\applet\wiring_serial.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\wiring_shift.c -oD:\arduino-0013\examples\Digital\Blink\applet\wiring_shift.c.o
D:\arduino-0013\hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\examples\Digital\Blink\applet\Blink.cpp -oD:\arduino-0013\examples\Digital\Blink\applet\Blink.cpp.o
D:\arduino-0013\hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\HardwareSerial.cpp -oD:\arduino-0013\examples\Digital\Blink\applet\HardwareSerial.cpp.o
D:\arduino-0013\hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\Print.cpp -oD:\arduino-0013\examples\Digital\Blink\applet\Print.cpp.o
D:\arduino-0013\hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega168 -DF_CPU=16000000L -ID:\arduino-0013\hardware\cores\arduino D:\arduino-0013\hardware\cores\arduino\WMath.cpp -oD:\arduino-0013\examples\Digital\Blink\applet\WMath.cpp.o
D:\arduino-0013\hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections -mmcu=atmega168 -o D:\arduino-0013\examples\Digital\Blink\applet\Blink.elf D:\arduino-0013\examples\Digital\Blink\applet\Blink.cpp.o D:\arduino-0013\examples\Digital\Blink\applet\HardwareSerial.cpp.o D:\arduino-0013\examples\Digital\Blink\applet\pins_arduino.c.o D:\arduino-0013\examples\Digital\Blink\applet\Print.cpp.o D:\arduino-0013\examples\Digital\Blink\applet\WInterrupts.c.o D:\arduino-0013\examples\Digital\Blink\applet\wiring.c.o D:\arduino-0013\examples\Digital\Blink\applet\wiring_analog.c.o D:\arduino-0013\examples\Digital\Blink\applet\wiring_digital.c.o D:\arduino-0013\examples\Digital\Blink\applet\wiring_pulse.c.o D:\arduino-0013\examples\Digital\Blink\applet\wiring_serial.c.o D:\arduino-0013\examples\Digital\Blink\applet\wiring_shift.c.o D:\arduino-0013\examples\Digital\Blink\applet\WMath.cpp.o -lm
D:\arduino-0013\hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 D:\arduino-0013\examples\Digital\Blink\applet\Blink.elf D:\arduino-0013\examples\Digital\Blink\applet\Blink.eep
D:\arduino-0013\hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom D:\arduino-0013\examples\Digital\Blink\applet\Blink.elf D:\arduino-0013\examples\Digital\Blink\applet\Blink.hex
system
March 10, 2009, 4:04pm
20
Andrew: No I only get the message from above
Festblatte
