Hello everybody,
Like always very short question.. Which one code will work faster? The second one?
digitalWrite(1, HIGH);
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, HIGH);
digitalWrite(12, HIGH);
digitalWrite(13, HIGH);
digitalWrite(1, LOW);
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(12, LOW);
digitalWrite(13, LOW);
for(i=0;i<14;i++)
digitalWrite(i, HIGH);
for(i=14;i>=1;i--)
digitalWrite(i, LOW);
P.S. I wrote this code only for better understanding. So it may be wrong, bet the main idea is clearly to see.
Thank you very much!
mmcp42
February 2, 2012, 1:17pm
2
1 will be a fraction faster as it doesn't have the overhead of the for loop
2 is smaller
they are different
2 sets pin 0 HIGH!!
both set pins HIGH in the same order
2 sets the pins LOW in reverse order
So the first one is faster. Thank you very much!
system
February 2, 2012, 1:57pm
4
Had this experimental code lying around...
HTH
// code speed test
unsigned const long RUN_CYCLES = 50000;
unsigned long startTime;
unsigned long endTime;
unsigned long avgTime = 0;
float avgTime_f = 0.0;
typedef void (*testFunction)(void);
void f1() {
void f2() {
unsigned short i;
for (i = 2; i <=13; i++) {
testFunction testFunctions[] = { f1, f2 };
#define ARYLEN(a) (sizeof(a)/sizeof(a[0]))
unsigned short i;
unsigned int k;
Serial.print("Testing ");
Serial.print(ARYLEN(testFunctions));
Serial.print(" function(s) for ");
Serial.print(RUN_CYCLES);
Serial.println(" cycles...");
for (i = 0; i < ARYLEN(testFunctions); i++) {
Serial.print("Function ");
Serial.print(i);
Serial.print("... ");
avgTime = 0;
for (k = 0; k < RUN_CYCLES; k++) {
startTime = micros();
(*testFunctions[i])();
avgTime += micros() - startTime;
avgTime_f = (float)avgTime / (float)RUN_CYCLES;
Serial.print(avgTime_f, 8);
Serial.println(" us/call");
Results:
Testing 2 function(s) for 50000 cycles...
Function 0... 108.98735809 us/call
Function 1... 115.27111816 us/call
edit: was ms/call, should have been instead us/call (microseconds)
system
February 2, 2012, 2:53pm
6
If you need high speed digital output on several channels you can access directly
the registers as illustrated here: Arduino Playground - PortManipulation
instead of using the digitalWrite function.
MarkT
February 2, 2012, 5:25pm
7
Mastino:
Only by a few percent, digitalWrite is a slow routine.
Perhaps you meant to ask "how do I do fast pin I/O?" to which the answer is direct-port manipulation.
Actually my question was - works the code faster if I use "for" function. You know there are a lot of ways to write the same code.
