Topic: Rubik's cube Robot solver (Read 120914 times) previous topic - next topic
alihan35
@alihan35
Here it is, remove the .txt extension and let me know if you can open it
I will share what I do on the forum.
thanks for everything . I can do it for files opened. next step with arduino software .
WitherKun
Hey, Kas. I was really impressed by your project. So i decided to make something similar, but using a smartphone. Could you please send me a link for the android app?
kas
#212
Mar 05, 2017, 08:01 am Last Edit: Mar 05, 2017, 08:16 am by kas
Quote
Just leave me your email via PM
The Android version is, in my opinion, the way to go
Two important advices:
- have the hardware (stand + grippers) build & tuned before messing with software
- understand Bluetooth connection using  Joystick BT Commander  (another free App)
Smartphone / Arduino connection is performed using a HC-05 or HC-06 board (3 bucks shipped)
You can also use a very convenient Arduino/HC-05 combo
Again, full details here
InsydeTech21
One question, When you mount the bottom servos that turn the rubix cube, what is the default angle?
kas
For the wrist (rotation) servo,default angle is 0°, servo will rotate 90° CW and 90° CCW
For the pinch servo, default angle is also 0°, but not critical as rotation is only 60 CW
Reminder:
Quote
Make sure that the rotation (wrist) servo can perform at least a full 180° move
Some servo's just can't  ::)
alihan35
#215
Mar 06, 2017, 10:40 pm Last Edit: Mar 06, 2017, 10:51 pm by alihan35
Hey Kas.
There seems to be a setback. It looks dull. Do you have a problem?
kas
#216
Mar 07, 2017, 07:57 am Last Edit: May 15, 2018, 10:21 am by kas
Looks promising   :)
Nuts should be very sightly tied, to avoid too much friction (untied 1/2 turn)
I suggest you use Nylock nuts and washers
Next important step is described in post #6
Make sure to use a smooth rotating cube (Dayan or equivalent)
Please post a video for this step
alihan35
hey Kas ! . I'm opening arduino code . but ı dont understand " bip ".  what is the " bip " pin ?
kas
#218
Mar 10, 2017, 08:25 pm Last Edit: Mar 10, 2017, 08:26 pm by kas
The Bip pin is connected to an active buzzer for signaling various events (end of scan, errors ...)
Please refer to post #118 for a full custom shield description
demirell95
Hello KAS
First of all, thank you for this excellent topic.
I started this project.
I print the holders with a 3d printer (thanks to the friend who shared the design)
Pictures:
http://i.resimyukle.xyz/3bOU1.jpg
http://i.resimyukle.xyz/PcUdR.jpg
kas
#220
Mar 20, 2017, 09:48 pm Last Edit: Mar 20, 2017, 09:50 pm by kas
Hello KAS
Pictures:
Hi demirell95
Nice job   8)  8)
Thanks for your feedback, keep us aware of your progress
Remainder: do not overlook the first test, as described in post #6   ;)
demirell95
Hi demirell95
Nice job   8)  8)
First of all I am sorry for my English, I don't know english :D (GOOGLE TRASNLATE)
Of course I will go step-by-step, #1, #2, #3 ...... I will try to give feedback in all stages.
benbowman
Hey Kas!
I've almost finished my hardware, just need a camera holster and i can get the program running.
here is what my design looks like (all 3D printed),
I'm getting exited and may have some questions about your code to come :)
I'll share again ones I've fixed the errors in my prints and have the cam holder working.
kas
#223
Mar 29, 2017, 08:12 am Last Edit: May 15, 2018, 10:21 am by kas
Hi benbowman
Superb implementation  :smiley-eek-blue:  :smiley-eek-blue:  :smiley-eek-blue:
See my comments (post #216) for nuts
Quote
Which road are you taking, Python or Android ??
I exhibited my robot last week at Maker Faire Grenoble and generated a LOT of interest  8)
demirell95
Hi benbowman
Hi Kas,
Are not the grippers too close together?
Does it create a problem?
Hi benbowman,
Can you share 3D design stl files(lower case)
