I've tried googling it but found nothing that meets the requirement. I have an autonomous robot that uses servos. On rare occasion, it gets stuck in some weird position that will cause the servo to burn up. If I had a circuit breaker or even a low amp automotive fuse, I could save myself some money.
You could look into "foldback current limiting"
https://www.google.ca/search?q=foldback+current+limiting&hl=en&tbo=u&rlz=1T4GZAZ_enCA411CA411&tbm=isch&source=univ&sa=X&ei=ipz0UMjcLuK2iwKmhIDABg&ved=0CDcQsAQ&biw=979&bih=401
David82:
Check radioshack
zoomkat:
Check radioshack
I appreciate the help but that's obviously not it. I did finally find the answer though for anyone else that finds this thread. You use what is called a polyfuse (aka, polyswitch). They are perfect. They are cheap and open the circuit when they get hot while closing the circuit when they cool down. Perfect.
David82:
zoomkat:
Check radioshackI appreciate the help but that's obviously not it. I did finally find the answer though for anyone else that finds this thread. You use what is called a polyfuse (aka, polyswitch). They are perfect. They are cheap and open the circuit when they get hot while closing the circuit when they cool down. Perfect.
Resettable fuse - Wikipedia
Yes I was just about to post about these:
http://www.epcos.com/inf/55/db/PTC_09/OC_Leaded_12V_160_C2_B0C_C_B599_5.pdf
Lefty
David82:
zoomkat:
zoomkat:
RadioShack.com Official Site - America's Technology Store
yea, that's them. that wasn't your original link. Anyway, those are just online and are, of course, going to be over priced since it's radioshack.
Sure they are, on the left side of the linked page is a listing of various types of fuses. I'd think you would start with a more conventional fuse for testing, but good luck with your polyfuse choise.
