Ho cambiato un pò il funzionamento, anche dopo aver letto di altri robot online.
Ecco il nuovo sketch funzionante:
#include <Servo.h>
#define motor1_pin1 2
#define motor1_pin2 3
#define motor2_pin1 4
#define motor2_pin2 5
#define ECHOPIN 6 // Pin to receive echo pulse
#define TRIGPIN 7 // Pin to send trigger pulse
#define fariled 8
int distance = 0;
int distanceleft = 0;
int distanceright = 0;
int object= 35;
Servo myservo;
void setup ()
myservo.attach(9);
pinMode(ECHOPIN, INPUT);
pinMode(TRIGPIN, OUTPUT);
pinMode(fariled, OUTPUT);
pinMode(motor1_pin1,OUTPUT);
pinMode(motor1_pin2,OUTPUT);
pinMode(motor2_pin1,OUTPUT);
pinMode(motor2_pin2,OUTPUT);
myservo.write(90);
delay(200);
digitalWrite(TRIGPIN, LOW); // Set the trigger pin to low for 2uS
delayMicroseconds(2);
digitalWrite(TRIGPIN, HIGH); // Send a 10uS high to trigger ranging
delayMicroseconds(10);
digitalWrite(TRIGPIN, LOW); // Send pin low again
int distance = pulseIn(ECHOPIN, HIGH); // Read in times pulse
distance= distance/58; // Calculate distance from time of pulse
if (distance <0 or distance >500) distance=0;
if (distance > object) {
avanti();
if (distance <= object) {
trovastrada();
void avanti() {
digitalWrite(fariled,HIGH);
digitalWrite(motor1_pin1,HIGH);
digitalWrite(motor1_pin2,LOW);
digitalWrite(motor2_pin1,HIGH);
digitalWrite(motor2_pin2,LOW);
digitalWrite(fariled,LOW);
return;
void trovastrada() {
fermati();
retro();
guardasinistra();
guardadestra();
if( distanceleft < distanceright) {
girasinistra();
else {
giradestra();
void retro() {
digitalWrite(motor1_pin1,LOW);
digitalWrite(motor1_pin2,HIGH);
digitalWrite(motor2_pin1,LOW);
digitalWrite(motor2_pin2,HIGH);
fermati();
return;
void fermati() {
return;
void ultrasuoni() {
void guardasinistra(){
myservo.write(30);
ultrasuoni();
distanceleft = distance;
Serial.print(distanceleft);
Serial.print(" ");
myservo.write(90);
return;
void guardadestra(){
myservo.write(150);
ultrasuoni();
distanceright = distance;
Serial.print(distanceright);
Serial.print(" ");
myservo.write(90);
return;
void girasinistra() {
fermati();
return;
void giradestra() {
fermati();
return;
Se qualcuno ha altri suggerimenti, li accetterò voltentieri.
Simone
