I use Arduino and java code from this web " www.arduino.cc/playground/Interfacing/Java " in Netbeans.I read data from serial port and I can display data in command line. But I want to display data in jTextArea .It doesn't have anything in jTextArea when I run this code, but have data in command line.How to display data from serial port in jTextArea1.
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import gnu.io.SerialPortEvent;
import gnu.io.SerialPortEventListener;
import java.io.InputStream;
import java.io.OutputStream;
import java.util.Enumeration;
public class SerialTest extends javax.swing.JFrame implements SerialPortEventListener {
SerialPort serialPort;
/** The port we're normally going to use. /
private static final String PORT_NAMES[] = {
"/dev/tty.usbserial-A9007UX1", // Mac OS X
"/dev/ttyUSB0", // Linux
"COM5", // Windows
/* Buffered input stream from the port /
private InputStream input;
/* The output stream to the port /
private OutputStream output;
/* Milliseconds to block while waiting for port open /
private static final int TIME_OUT = 2000;
/* Default bits per second for COM port. */
private static final int DATA_RATE = 9600;
/** Creates new form SerialTest */
public SerialTest() {
initComponents();
public void initialize() {
CommPortIdentifier portId = null;
Enumeration portEnum = CommPortIdentifier.getPortIdentifiers();
// iterate through, looking for the port
while (portEnum.hasMoreElements()) {
CommPortIdentifier currPortId = (CommPortIdentifier) portEnum.nextElement();
for (String portName : PORT_NAMES) {
if (currPortId.getName().equals(portName)) {
portId = currPortId;
if (portId == null) {
System.out.println("Could not find COM port.");
return;
try {
// open serial port, and use class name for the appName.
serialPort = (SerialPort) portId.open(this.getClass().getName(),
TIME_OUT);
// set port parameters
serialPort.setSerialPortParams(DATA_RATE,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
// open the streams
input = serialPort.getInputStream();
output = serialPort.getOutputStream();
// add event listeners
serialPort.addEventListener(this);
serialPort.notifyOnDataAvailable(true);
} catch (Exception e) {
System.err.println(e.toString());
- This should be called when you stop using the port.
- This will prevent port locking on platforms like Linux.
public synchronized void close() {
if (serialPort != null) {
serialPort.removeEventListener();
serialPort.close();
- Handle an event on the serial port. Read the data and print it.
public synchronized void serialEvent(SerialPortEvent oEvent) {
if (oEvent.getEventType() == SerialPortEvent.DATA_AVAILABLE) {
try {
int available = input.available();
byte chunk[] = new byte[available];
input.read(chunk, 0, available);
// Displayed results are codepage dependent
System.out.print(new String(chunk)); // I can display data here in command line.
jTextArea1.append(new String(chunk)); // I can't display data here in jTextField1.
// Ignore all the other eventTypes, but you should consider the other ones.
/** This method is called from within the constructor to
- initialize the form.
- WARNING: Do NOT modify this code. The content of this method is
- always regenerated by the Form Editor.
@SuppressWarnings("unchecked")
private void initComponents() {
jScrollPane1 = new javax.swing.JScrollPane();
jTextArea1 = new javax.swing.JTextArea();
jTextField1 = new javax.swing.JTextField();
setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
jTextArea1.setColumns(20);
jTextArea1.setRows(5);
jScrollPane1.setViewportView(jTextArea1);
jTextField1.setText("jTextField1");
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(layout.createSequentialGroup()
.addContainerGap()
.addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addComponent(jTextField1, javax.swing.GroupLayout.PREFERRED_SIZE, 126, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, 371, javax.swing.GroupLayout.PREFERRED_SIZE))
.addContainerGap(19, Short.MAX_VALUE))
layout.setVerticalGroup(
.addContainerGap()
.addComponent(jScrollPane1, javax.swing.GroupLayout.PREFERRED_SIZE, 207, javax.swing.GroupLayout.PREFERRED_SIZE)
.addGap(18, 18, 18)
.addComponent(jTextField1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addContainerGap(44, Short.MAX_VALUE))
pack();
@param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new SerialTest().setVisible(true);
SerialTest main = new SerialTest();
main.initialize();
System.out.println("Started");
// Variables declaration - do not modify
private javax.swing.JScrollPane jScrollPane1;
private javax.swing.JTextArea jTextArea1;
private javax.swing.JTextField jTextField1;
// End of variables declaration
