Topic: Tally light System (Read 689 times) previous topic - next topic
drorshalit
hallow everybody....
i am a beginner so go easy on me....
i have an Genuino UNO board. i want that the bard will be a tally light system
meaning that i have a software by the name of Vmix that can connect to the Genuino UNO board and when i switch cameras in my software i get a red light from the selected pin of the board.
i saw some projects like that but on  a Arduino UNO board... (is it make any difference?)
they loaded the standard firmata example and it work for them but when i load this example the system is working on the opposite whey
all the light that so posed to be off are on and the one on air is off....
can any one help me with the code?
about the wiring i am doing fine so my problem is only the code....
best regards!  ;D
Robin2
What code?
You have not posted any!
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
drorshalit
in my post i mantion that i used the standard firmata hear is the code :)
thank you!
code link
https://github.com/firmata/arduino/blob/master/examples/StandardFirmata/StandardFirmata.ino
Robin2
#3
May 19, 2017, 11:36 pm Last Edit: May 19, 2017, 11:39 pm by Robin2
Sorry. I have never used that. I don't even know what it is for.
I had assumed you had some particular code that would identify some things for me, including how you are controlling the lamps.
What sort of lamps are you using. If you are using LEDs they may be working the wrong way just because they are connected the wrong way.
...R
sdturner
Are you certain that your Computer is sending the same messages? Could the bits be flipped?
Are your LEDs wired the same way as the example you saw? The polarity to turn a LED on or off will be reversed if you connect the LED and Resistor to Ground or to VCC.
If that doesn't work go into the Firmata code and change the polarity of the pins you are using.
lastchancename
You may get better answers if you add VMIX in the subject.
Then people that have used it before are likely to see your thread.
When posting - use the toolbar and read the stickies if you're not sure!  </code> tags are our friend!
You can lead a plug to an outlet, but you can't make them turn it on.
allanhurst
VMIX is a video processing software suite for use on a pc - presumably with a high performance video card.
What has an arduino to do with this?
Allan
MorganS
If the tally lights are all reversed, then it would not be too hard to use an N-type MOSFET on each one to reverse the sense of the output. An N-MOSFET is "on" when its input is LOW and "off" when its input is HIGH.
"The problem is in the code you didn't post."
