Topic: How to measure distance between IR beacons? (Read 167 times) previous topic - next topic
amnah
May 20, 2017, 02:43 am Last Edit: May 20, 2017, 02:50 am by amnah
Hi, I am working on a robot that follows me around using a pair of Pololu IR beacons and it worked fine but I want it to stop if it gets too close so I was wondering if it's possible to measure the distance using the IR sensors.
I installed an ultrasonic sensor to avoid obstacles on the way.
I could use some ideas :) thank you.
Grumpy_Mike
Not with the sessors you have at the moment. But you can get an IR distance sensor like this Distance sensor they work off the reflected angle of the return beam.
