The libraries are present and the include statement does not generate an error.
The include also has the updated Arduino filename.
The file extensions also appear to be correct.
I am guessing that it may be something to do with libraries as I have not used them yet.
AFAICS there is no syntax error.
Many other errors but hoping once I understand this one I can fix the rest
Then the MAX31855 wasn't downloaded/installed correctly.
Yes the zip file was incomplete.
.h is here
This is a library for the Adafruit Thermocouple Sensor w/MAX31855K
Designed specifically to work with the Adafruit Thermocouple Sensor
----> https://www.adafruit.com/products/269
These displays use SPI to communicate, 3 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class Adafruit_MAX31855 {
public:
Adafruit_MAX31855(int8_t SCLK, int8_t CS, int8_t MISO);
double readInternal(void);
double readCelsius(void);
double readFarenheit(void);
uint8_t readError();
private:
int8_t sclk, miso, cs;
uint32_t spiread32(void);
.cpp is here
interface
#include "Adafruit_MAX31855.h"
#include <avr/pgmspace.h>
#include <util/delay.h>
#include <stdlib.h>
Adafruit_MAX31855::Adafruit_MAX31855(int8_t SCLK, int8_t CS, int8_t MISO) {
sclk = SCLK;
cs = CS;
miso = MISO;
//define pin modes
pinMode(cs, OUTPUT);
pinMode(sclk, OUTPUT);
pinMode(miso, INPUT);
digitalWrite(cs, HIGH);
double Adafruit_MAX31855::readInternal(void) {
uint32_t v;
v = spiread32();
// ignore bottom 4 bits - they're just thermocouple data
v >>= 4;
// pull the bottom 11 bits off
float internal = v & 0x7FF;
internal *= 0.0625; // LSB = 0.0625 degrees
// check sign bit!
if (v & 0x800)
internal *= -1;
//Serial.print("\tInternal Temp: "); Serial.println(internal);
return internal;
double Adafruit_MAX31855::readCelsius(void) {
int32_t v;
v = spiread32();
//Serial.print("0x"); Serial.println(v, HEX);
float internal = (v >> 4) & 0x7FF;
internal *= 0.0625;
if ((v >> 4) & 0x800)
internal *= -1;
if (v & 0x7) {
// uh oh, a serious problem!
return NAN;
// get rid of internal temp data, and any fault bits
v >>= 18;
//Serial.println(v, HEX);
// pull the bottom 13 bits off
int16_t temp = v & 0x3FFF;
// check sign bit
if (v & 0x2000)
temp |= 0xC000;
//Serial.println(temp);
double centigrade = v;
// LSB = 0.25 degrees C
centigrade *= 0.25;
return centigrade;
uint8_t Adafruit_MAX31855::readError() {
return spiread32() & 0x7;
double Adafruit_MAX31855::readFarenheit(void) {
float f = readCelsius();
f *= 9.0;
f /= 5.0;
f += 32;
return f;
uint32_t Adafruit_MAX31855::spiread32(void) {
int i;
uint32_t d = 0;
digitalWrite(sclk, LOW);
_delay_ms(1);
digitalWrite(cs, LOW);
_delay_ms(1);
for (i=31; i>=0; i--)
_delay_ms(1);
d <<= 1;
if (digitalRead(miso)) {
d |= 1;
digitalWrite(sclk, HIGH);
_delay_ms(1);
//Serial.println(d, HEX);
return d;
The most recent ino file from rocketscream at github only seems to reference the max31855 library though.
max31855.h
interface
#else
#endif
public:
private:
max31855.cpp
interface
#include <stdlib.h>
sclk = SCLK;
cs = CS;
miso = MISO;
//define pin modes
uint32_t v;
v = spiread32();
v >>= 4;
// check sign bit!
if (v & 0x800)
internal *= -1;
return internal;
int32_t v;
v = spiread32();
internal *= 0.0625;
internal *= -1;
if (v & 0x7) {
return NAN;
v >>= 18;
// check sign bit
if (v & 0x2000)
temp |= 0xC000;
centigrade *= 0.25;
return centigrade;
f *= 9.0;
f /= 5.0;
f += 32;
return f;
int i;
uint32_t d = 0;
_delay_ms(1);
_delay_ms(1);
_delay_ms(1);
d <<= 1;
d |= 1;
_delay_ms(1);
return d;
I have tried going through the ino file and changing MAX31855.h to adafruit_MAX31855.h but to no avail.
all the above came in the same zip file and are said to work together.
Now I read my last post and understand.
The ino uses the max31855 library but the one I have appears to be a renamed copy of the addafruitmax31855 library.
I would have spotted this much earlier but the ide will not open cpp or h files and my text editor would not display the properly,cr/lf missing causes the file to be displayed as one line.
Another vote for Notepad++
It can be set to understand C++ source files so that functions and for/while loops etc are recognised and highlighted and can be collapsed to make better use of screen space.
