millis(); not updating with the same loop
im trying to determine how much time has elapsed for a few lines of code:
//Read Flow Meter
  countA=0;
  cTime=millis();
  for(int xCount=0; xCount<10001; xCount++){
    int signalA = digitalRead(rpm_rd3); //detects tachometer signal, flow pin goes high every time the magnet spins past the sensor. NOTE: must be int.
    if(signalA==1){
      countA++;
  pTime=millis();
  FLOWCALC = countA/((pTime-cTime)/1000)*60;
but cTime and pTime are returning the same time.
this is a portion of code. i know the values are the same as i have them reading out to a 20x4 LCD.
i know i could use interrupts for this but i am using a Arduino UNO IDE 1.0.3 and pins 2 and 3 are being used for capturing RPMs from a pump and a fan using interrupts 0 and 1.
original code idea from Arduino Flowmeter | DaveBMiller
It's quite possible that your 10000 cycle loop takes less than a millisecond to execute
Instead of millis() try using micros() as a 16mhz AVR chip may run code a lot faster then you appreciate. :wink:
http://arduino.cc/en/Reference/Micros
Lefty
thanks i'll give that a try.
also wondering if serial needs to be running as the examples i have seen have it running at 9600 or 19200.
not sure if that makes a difference.
What do you mean by "serial is running" ? It's not like Serial.begin() starts some kind of background process :slight_smile:
Notice that this is ALL integer arithmetic. Unless the loop takes more than a second to execute (highly unlikely), (pTime - cTime)/1000 will always be 0. (pTime - cTime)/1000.0 would not.
digitalread takes in the order of 1-4 uSec the loop should be above 10 millisecs at least. using micros() is OK but won't solve the error I expect..
Note you are doing 10001 iterations, and divide by 1000
I don't know the datatypes of the vars used but if ptime and ctime are int/long and ãpprox 40 apart, dividing by 1000 will return zero * 60 is still zero.
Integer math is not forgiving.
Try this formula instead (make ptime and ctime and flowcalc unsigned long )
FLOWCALC = (countA * 60000L)/(pTime-cTime);
Style remark:
It is quite common in C/C++ to write constants/#defines only in upper case and variables not. So FLOWCALC is misleading because of its style.
