You may have several problems. Sounds like you may have overlapping request to the server.The w5100 based ethernet shield is only setup for four connections, and your code apparently has nothing to close the current connection when the data is received. Below is some simple client test code for reference.
//zoomkat 11-13-10
//simple ethernet client test code
//for use with IDE 0021 and W5100 ethernet shield
//modify the arduino lan ip address as needed
//open serial monitor to see what the arduino receives
//push the shield reset button to run client again
#include <SPI.h>
#include <Ethernet.h>
byte ip[] = { 192, 168, 1, 102 }; // Arduino IP address
byte server[] = { 208, 104, 2, 86 }; // zoomkat's web site
Client client(server, 80);
Ethernet.begin(mac, ip);
Serial.println("starting simple arduino client test");
Serial.println();
Serial.println("connecting...");
if (client.connect()) {
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0");
client.println();
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
Serial.println("==================================");
Serial.println("");
client.stop();
for(;;); //stops loop for a single get request.
