system
1
I am planning to buy some ATmega128 (TQFP64) and some DIP adapter (http://www.elecfreaks.com/store/qfp324464-to-dip-adapter-08mm-pitch-p-245.html).
My problem is to discover the correct pitch I need to look for. 0.8mm or 0.5mm.
I believe that ATMega128 is 0.8mm. Am I right ?
dc42
2
See the Packaging Information section in http://www.atmel.com/Images/doc2467.pdf.
Riva
3
According to the data sheet 0.8
doc2467x.pdf (95.5 KB)
system
4
Thank you !
Some day I will know how to read the entire datasheet
Now I understand that there are two packages: 64A (0.8mm) and 64M1 (0.5mm). But only the 64A is TQFP.
Thanks again !!!
