Hello all!
I'm a new member to the arduino community.
I received my duemilanove yesterday in the mail and she is indeed a beauty.
This morning I started familiarizing myself with coding and decided "why not make my own?".
After an hr or 2 (lost count) of trial and error, I finally came up with this short traffic light LED code.
Try it for yourself =)
// Traffic light code designed by Marquez Santos! (on facebook)
// Connect green LED to pin 13
// Connect yellow LED to pin 12
// Connect red LED to pin 11
// declare pin 11,12,13 to be outputs:
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
void loop(){{
digitalWrite(13, HIGH); // Turns LED on pin 13 on
delay(2500); // LED on pin 13 remains on for 5 seconds
digitalWrite(13, LOW); // Turns LED on pin 13 off
delay(0);}
digitalWrite(12, HIGH); // Turns LED on pin 12 on
delay(2500); // LED on pin 12 remains on for 5 seconds
digitalWrite(12, LOW); // Turns LED on pin 12 off
delay(0);
digitalWrite(11, HIGH); // Turns LED on pin 11 on
delay(2500); // LED on pin 11 remains on for 5 seconds
digitalWrite(11, LOW); // Turns LED on pin 11 off
delay(0);
Double lane code below
// Connect green LED to pin 13 and 7
// Connect yellow LED to pin 12 and 6
// Connect red LED to pin 11 and 5
int var = 0;
// declare pins 11,12,13,5,6,7 to be outputs:
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
void loop(){{delay(1000);
if (var == 0)
digitalWrite(5, HIGH);
delay(0);
var = 1;
if (var == 1)
delay(0);
var = 0; }
{ delay(7000);
if (var == 0)
delay(0);
var = 1;
if (var == 1)
delay(0);
var = 2;}
delay(5000);
if (var == 2)
delay(0);
var = 2;
if (var == 2)
delay(0);
var = 3;
{ delay(3000);
if (var == 3)
delay(0);
var = 4;
if (var == 4)
delay(0);
var = 3;
delay(3000);
if (var == 3)
delay(0);
var = 2;
if (var == 2)
digitalWrite(5, LOW);
delay(0);
var = 2;
if (var == 2)
digitalWrite(7, HIGH);
delay(0);
var = 4;}
{ delay(5000);
if (var == 4)
delay(0);
var = 2;
if (var == 2)
digitalWrite(7, LOW);
delay(0);
var = 3;
if (var == 3)
digitalWrite(6, HIGH);
delay(0);
var = 2; }
{ delay(3000);
if (var == 2)
digitalWrite(6, LOW);
delay(0);
var = 3;
if (var == 3)
delay(0);
var = 4;
if (var == 4)
delay(0);
var = 3; }
{delay(3000);
if (var == 3)
delay(0);
var = 4;
if (var == 4)
delay(0);
var = 3; }
{delay(000);
if (var == 3)
delay(0);
var = 2;
if (var == 2)
digitalWrite (13, HIGH);
delay(0);
var = 3; }
