Topic: ProMini with G. Bunzas Accessory DCC control of servos and leds. PB switches??? (Read 144 times) previous topic - next topic
dacum47
I am NOT a programmer in C++ and minimally understand what a program is doing,  I need help with the programming.
I am using multiple Arduino Pro Minis that use Geoff Bunzas Accessory Decoder sketch (modifed) to control 8 turnout servos and 8 position indicator LED's.  This is working on my DCC system using switch commands.  I would like to incorporate push button switches to throw turnouts manually without breaking DCC control.  Feedback to the system is not required (yet).
I have posted a modified version of the sketch using 5 servos and 5 LEDs outputs.
Where and what would I place in the program to get switch press data (pin 5) into the mix to do the same thing as the SW001 {closed or thrown) command?
All comments appreciated.
Coding Badly
I want to remove the attachment and add another. How do I do it?
Click More then Modify (lower right corner of each post) then Attachments and other options then the checkmark next to the file you want to remove.
dacum47
