Can you run the i2c_scanner ?
http://playground.arduino.cc/Main/I2cScanner
If it doesn't find an I2C addres, you have a display that can not pull the SDA low for an acknowledge. I don't know if the u8glib can do that. I have seen a library for that, perhaps I can try to find it if you want.
thanks for the answers.
olikraus:
Did you apply pull up resistors for the display?
Which Arduino board do you use?Oliver
No, there are no pull up resistors. Do I need one?
Caltoa:
Arduino Playground - I2cScanner
Thank you for this hint. The scanner finds no devices.
MAS3:
I reported this thread to a moderator, itwill probably behas been put in the Display section.Have a look at this thread (click).
It is about this display, but on an other pcb.
At the end u8glib is discussed here, and u8glib has its own topic in this Display section.
I'll have a closer look into that on this evening. Thank you.
Yes, one 4.7K for SCL and another 4.7K for SDA. One end of the resistor to +5V (i assume that this is a 5V tolerant display module) and the other end of the resistor to the signal lines SCL and SDA.
Once these resistors are there,. the scanner should find a device at 0x3c.
Oliver
olikraus:
No. Resistors are there, but the scanner says "No devices found"
In that case, you might have a super cheap OLED, that can only read I2C and can not acknowledge it.
Does it say 'heltec.cn' on the backside ?
The rar file on this page contains code for it.
http://www.wide.hk/products.php?product=I2C-0.96"-OLED-display-module-(-compatible-Arduino-)
That code doesn't do anything special, so perhaps the u8glib will work with it.
They say it is Adafruit compatible, perhaps you can use the Adafruit library or the u8glib with Adafruit mode.
For the u8glib, you have to ask in the u8glib thread if the display is supported.
I only started recently using u8glib with another super cheap OLED.
http://forum.arduino.cc/index.php?topic=217290.0
Caltoa:
Yes, it's one of those super cheap OLEDs with heltec.cn on the backside.
Caltoa:
They say it is Adafruit compatible, perhaps you can use the Adafruit library or the u8glib with Adafruit mode.For the u8glib, you have to ask in the u8glib thread if the display is supported.
OLED display with 4-wire SPI mode, but without CS - Displays - Arduino Forum
I tried the code from wide.hk, but nothing happens
Perhaps something else is wrong with it. Perhaps it is broken. Sorry, but I don't know what else you could do.
Maybe you can post a picture of your setup to verify your wiring.
Oliver
Wiring seems okay.
Yes.
Do you know what I can do, to test if it's broken? Using a multimeter or something?
hmm... i am also running out of ideas... In those cases i usually start to use my scope to observere activity on the signal and clock lines.
Oliver
My best advice at this point it to forget that display.
Buy a better display from a good company that sells electronics which work: Monochrome 0.96 128x64 OLED Graphic Display - STEMMA QT : ID 326 : $17.50 : Adafruit Industries, Unique & fun DIY electronics and kits
Hello,
I just wanted to tell you, that the module is working now.
I wrote to the chinese seller, and he sent me a link to a chinese website with a working library and code: 14blog.com
Google-translate does hard work on this page
BTW the module doesn't need any resistors, and it works on every digital pin.
Thanks for help!
Regards.
@ Oliver:
Can you please take a look at the library and check if the module works also with u8glib?
The provided library is really "buggy".
Thanks for the feedback. Main problem is, that i do not own this display. So i can not do any tests on it.
Oliver
olikraus:
Thanks for the feedback. Main problem is, that i do not own this display. So i can not do any tests on it.Oliver
OK. Thanks anyway!
I have ordered the same display from this china seller. Usually it will take some weeks, but once it is here i will verify this.
Oliver
olikraus:
I have ordered the same display from this china seller. Usually it will take some weeks, but once it is here i will verify this.Oliver
GREAT! Thank you! Danke dir!
Interesting.
So they use I2C without acknowledge, because SDA can not pull the line low, as I suspected.
But they use a library with software I2C that can be used on any pin ?
I clicked the download link, but did not get a file.
