How does it mount to the Prop? Screws? Tape? Bubblegum? Does it run along only 1 blade or is it across 2 of them?
Do you have a header for connecting and disconnecting the device?And just out of curiousity, not as a critique, does everything mount to the prop, or do you have some form of rotating connector?
it mounts to the 'prop', as in it, presses up to a 'window' and is secured from behind (I believe there are some screws and some pieces/plate' to hold it up)
not sure what you mean by 'does it run along one blade or two'? its a single 'string' (matrix wired) to be used as a 'counter' (although Im sure other animations could be done.. ie: larson effect...or whatever you wanted)
*there is no header... there are 'pads' to direct solder wires to
- yes I believe everything will mount IN the prop. this 'bargraph/counter' will be mounter in one section/area..... there will also be another 'brain/arduino' in the main unit/area of the prop there will be some sort of wire connector used but it really irrelevant at this point.. as it will be determined by what fits the actual prop/mating areas best.
thanks!
anbody got some feedback on the schematic? any errors? the pcb passes the design rules check so I'll leave it up for a few more days before giving it a 'try' and ordering.
thanks!
