im attempting to compile an MTX contorol program for my rainbowduino, but the compiler tells me this:
Rainbowduino.cpp:0: error: expected, constructor, destructor, or type conversion before '/' token
and im not sure how i go about fixing that, i am using arduino 0022, heres the code:
the PDE:
* Firmware.h version 1.02 - to run mtXcontrol Rainbowduino/Arduino
* Copyright (c) 2009 Tobias Bielohlawek -> http://www.rngtng.com/mtxcontrol
#include <EEPROM.h>
* Rainbowduino.h && Rainbowduino.cpp are symbolically linked to make it compile right from the beginning.
* It's way more clean if you move "rainbowduino" Folder (including Rainbowduino.h && Rainbowduino.cpp) to you Arduino library
* and remove those links
#include "Rainbowduino.h"
#define LIVE 0
#define STANDALONE 1
#define BAUD_RATE 9600
#define CRTL 255
#define RESET 255
#define WRITE_FRAME 253
#define WRITE_EEPROM 252
#define READ_EEPROM 251
#define SPEED 249
#define SPEED_INC 128 //B1000 0000
#define SPEED_DEC 1 //B0000 0001
#define DEFAULT_SPEED 5000
Rainbowduino rainbow = Rainbowduino(10); //max 10 Frames
//running mode
byte mode = STANDALONE;
word current_delay = 0;
word current_speed = DEFAULT_SPEED;
void setup_timer()
TCCR2A |= (1 << WGM21) | (1 << WGM20);
TCCR2B |= (1<<CS22); // by clk/64
TCCR2B &= ~((1<<CS21) | (1<<CS20)); // by clk/64
TCCR2B &= ~((1<<WGM21) | (1<<WGM20)); // Use normal mode
ASSR |= (0<<AS2); // Use internal clock - external clock not used in Arduino
TIMSK2 |= (1<<TOIE2) | (0<<OCIE2B); //Timer2 Overflow Interrupt Enable
TCNT2 = 0xE7; //gamma value
sei();
//Timer2 overflow interrupt vector handler
ISR(TIMER2_OVF_vect) {
rainbow.draw();
Serial.begin(BAUD_RATE);
load_from_eeprom(0);
reset();
setup_timer();
void reset() {
rainbow.reset();
current_delay = 0;
mode = STANDALONE;
check_serial();
next_frame();
void next_frame() {
if( mode == LIVE ) return;
if(current_delay < 1) {
current_delay = current_speed;
rainbow.next_frame();
current_delay--;
void check_serial() {
if( !Serial.available() ) return;
byte value = read_serial();
if( value == CRTL ) {
switch( wait_and_read_serial() ) {
case RESET:
reset();
case WRITE_EEPROM: // TODO: add handshake sequence here???
write_to_eeprom(0);
case READ_EEPROM:
send_eeprom(0);
case WRITE_FRAME:
write_to_current_frame();
mode = LIVE;
case SPEED:
value = wait_and_read_serial();
if( value == SPEED_INC && current_speed > 100 ) current_speed -= 100;
if( value == SPEED_DEC ) current_speed += 100;
byte read_serial() {
return Serial.read();
byte wait_and_read_serial() {
while( !Serial.available() );
return read_serial();
void write_to_current_frame() {
for(byte row = 0; row < rainbow.num_rows; row++) {
rainbow.set_current_frame_row(row, wait_and_read_serial());
void write_to_eeprom( word addr ) {
word num_frames = wait_and_read_serial();
EEPROM.write(addr++, num_frames);
for( word frame_nr = 0; frame_nr < num_frames; frame_nr++ ) {
for( byte row = 0; row < rainbow.num_rows; row++ ) {
EEPROM.write(addr++, wait_and_read_serial()); //TODO: this will likely fail if addr is bigger than we actually can adress
void send_eeprom( word addr ) {
word num_frames = EEPROM.read(addr++);
num_frames = min(rainbow.max_num_frames, num_frames);
Serial.write(num_frames);
Serial.write( EEPROM.read(addr++) );
delay(1);
void load_from_eeprom( word addr ) {
rainbow.set_num_frames(EEPROM.read(addr++));
for( word frame_nr = 0; frame_nr < rainbow.num_frames; frame_nr++ ) {
rainbow.set_frame_row(frame_nr, row, EEPROM.read(addr++));
