Topic: Error on Wifi.config manual on the website ? (Read 400 times) previous topic - next topic
tfoutfou
Hi , i thing there is an error on this page
https://www.arduino.cc/en/Reference/WiFiConfig
Quote
WiFi.config(ip);
WiFi.config(ip, dns);
WiFi.config(ip, dns, gateway);
WiFi.config(ip, dns, gateway, subnet);
After many test and struggle i find out that the correct order for the options are :
Quote
Ip , Gateway , Subnet , DNS
there is no way that i know to change the order for the different adresses.
so the RIGHT order is :
Quote
WiFi.config(ip);
WiFi.config(ip, gateway);
WiFi.config(ip, gateway, subnet);
WiFi.config(ip, gateway, subnet, dns);
I also found that you cant declare a DNS if you have not filled a subnet before  , wich is logic because it is the last parameter
it would be nice for others if the changes can be made.
Thanks
