I've been searching around the forum for a similar problem as mine, but I did not find anything.
Here's my problem:
For my project, (I'm using a Duemilanove board) I'm trying to get a servo to work with the NewSoftSerial library without the random servo movements. I tried downloading the servo library from 0016 version and copying that library to my 0018 library, but that servo library will not work for some reason. I also tried using the SoftwarwServo library, but that library would not work either.
By "not working" I mean I get no servo movement at all. The code compiles but the servo does nothing. I even tried uploading the example servo codes, which wouldn't work.
When I use the servo library from 0018 with the NewSoftSerial, the servo jumps around to random positions while it is being powered.
Also, I know the servo is good, I tried it without the NewSoftSerial library and it worked fine.
What are you using NewSoftSerial for? It has nothing to do with moving the servo.
If you are reading data from a software serial port and using that data to position the servo, there may be a coding issue. Hard to say without seeing the code.
Yes it seems to be just the declaration of NewSoftSerial is causing the problem, it was acting fine before I added that library
I'm using digital pins 2 (tx on Arduino, rx on GPS) and 3 (rx on Arduino, tx on GPS), and digital pin 6 for the servo
I tried going back to the older version because I read that was fix for people using 0017 version, but I wasn't sure if that problem was fixed with 0018.
I'm using the software serial port to set my tx and rx pins, like this:
NewSoftSerial nss(3, 2);
This is my first time working with serial ports, is there another way to do this?
I'll try detaching the servo when not in use and see if that fixes it.
Heres a little piece of my code...
myservo.attach(6);
myservo.write(90); // servo will go to this position
delay(5000); // I just put the delay in just to see if the
pinMode(led, OUTPUT); // servo would jump around, it didn't
//eepromClear();
nss.begin(4800);
lcd.begin(16,2);
pinMode(offPin, OUTPUT);
after the delay, it jumps around to random positions
Ok, so I thought I would need to use NewSoftSerial to pull data from the GPS, but I got rid of that and just used Serial, along with the rx and tx pins on the arduino, which is working for now.
But is there any way to get around having to disconnect my gps from the digital pins when I have the arduino hooked up via USB? With the GPS plugged in I cannot upload anything to my board.
