There was surprisingly little interest in this topic but I will at least share the code I have now that I have finally gotten it to work. As far as I can see, the NEC-protocol works roughly as follows:
preamble:
8000us carrier ON
4000us OFF
device code:
8 bit code
8 bit code inverted (1 becomes 0, 0 becomes 1)
command code:
8 bit code
560us carrier ON
For the data part, a 0 is transmitted as:
560us carrier ON
565us OFF
...and a 1 is transmitted as
560us carrier ON
1690us OFF
Here comes the code:
int irPin = 13;
int data[32];
int val;
int timeout = 0;
pinMode(irPin, OUTPUT);
Serial.println("System ready!");
if(Serial.available())
//get and decode first byte
val = Serial.read();
Serial.print("Byte1: ");
Serial.println(val);
makedata(val, 0);
//get and decode second byte
timeout = millis();
while(!Serial.available() && millis() < timeout + 100) {}
Serial.print("Byte2: ");
makedata(val, 16);
//send preamble
oscWrite(irPin, 8000);
delayMicroseconds(4000);
//send data
for(int i = 0; i < 32; i++)
//space
oscWrite(irPin, 560);
//data
if(data[i] == '0')
delayMicroseconds(565);
Serial.print('0');
delayMicroseconds(1690);
Serial.print('1');
Serial.println();
void oscWrite(int pin, int time)
for(int i = 0; i < (time / 26) - 1; i++)
digitalWrite(pin, HIGH);
delayMicroseconds(13);
digitalWrite(pin, LOW);
void makedata(double foo, int ofs)
for(int i = 0; i < 8; i++)
data[i + ofs] = '0';
data[i + ofs + 8] = '0';
if(foo / 2 > floor(foo / 2))
data[i + ofs] = '1';
data[i + ofs + 8] = '1';
foo = floor(foo / 2);
And here is a small list of the 256 possible device codes (the numbers are ASCII-codes):
56 = device code for our TV
0-9 = channel 0-9
10 = -- (2 digit channel)
12 = channel up
13 = channel down
17 = "normal" (set volume low)
20 = TV/AV
21 = mute
22 = volume up
23 = volume down
24 = OK
25 = menu (says "sleep", don't know what this is)
26 = menu - color
28 = power
29 = last channel (P<->P)
64 = mono/stereo
66 = menu - color
69 = on-screen clock
70 = text tv
75 = sound bass?
76 = on-screen clock
85 = sound bass?
125 = volum max?! RETARDEEEED!
128 = volum max?! RETARDEEEED!
I haven't gotten further than 128. It was getting late last night and when I stumbled onto those two codes that set the volume to max I decided to stop for the time beeing before my girlfriend decided to take a roller to the back of my head or something. -__-'
Anyways, I'm waiting for my internet hookup and my brand new HTC S730 phone. With this, I will make a smooth interface to control the arduino (and thus the TV, DVD-player, a couple of LED-bars and who knows what else). I can hardly wait! =D
