When ever I try to run Arduino on my Comp (Ver 0012 and Ver 0011), I get the following error:
Error building library "Ethernet" utility\w5100.c: In function 'wiz_write_buf': utility\w5100.c:850: internal compiler error: Illegal instruction Please submit a full bug report, with preprocessed source if appropriate. See //sourceforge.net/tracker/?atid=520074&group_id=68108&func=browse for instructions.
I tried Sourceforge for help but could not get anywhere. I use the same program on a diferent comp with celeron processor and it works fine. my comp has VIA samuel processor!!
Very strange. If you don't need to use the Ethernet library, you can just delete the hardware/libraries/ethernet sub-directory of the Arduino application directory.
after deleting the ethernet library, this is now the new error:
"error building Library Firmata"
Firmata.cpp: In member function 'void FirmataClass::systemReset()':
Firmata.cpp:451: internal compiler error: Illegal instruction
See URL:http://sourceforge.net/tracker/?atid=520074&group_id=68108&func=browse for instructions.
