Hello,
I am trying to trigger a relay with an arduino mega.
i have use this cabling (see on the image)
When i put high voltage on the output 13 on arduino nothing happen on the relay
Do you know why ? Is my relay the good one ? see the picture of the relay
i took a picture of the relay it seems that it is a 6VDC relay (on the coil) ?
and it seems that this relay can manage 125VAC or 30VDC ?
please confirm?
Thanks
(deleted)
hi
the ground and the 5v are provided by arduino board (the good cabling below)
is the relay a 6VDC relay?
is this relay can manage 125VAC or 30VDC ?
Regards
pinMode (13,OUTPUT) in setup ??
Yes i did it
And 5v is in the exit if the output , i checked with a voltmeter
Maybe the Arduino 5V can't supply enough current?
BTW, when you put 5V across the relay with no other electronics to complicate things, can you hear it switch?
no i can't hear it switching
but i connected my relay with only 5V and GND on the coil and this time i hear it switching.
does my electronic is wrong ?
So it seems the relay is ok?
Now try the circuit you have, but with the relay given 5V of its own, not from Arduino. (Remember to connect all the grounds)
yes i think the relay is ok
i already try to connect another 5V source (another than arduino) and of course connected the ground
but nothing move
do you have an idea ?
The transisitor? You sure it's ok? Connected the right way round?
i try 3 transistor 2x2N222A and one BC548
i was wondering if the relay was the good one
because on the side it is written
SRC-S-06VDC
1A 30VDC 125VAC
any clue about this relay ?.
Measure voltage over trasister (C-E) with logical HIGH at base. If more then 0.4..0.5V decrease R at base to 330Ohm
hello
with a 220 Ohms resistance and HIGH at the base, I get 0 volts between C and E
with a 400 Ohms resistance and HIGH at the base, I get 0 volts between C and E
with a 500 Ohms resistance and HIGH at the base, I get 0 volts between C and E
Just to be sure, i put my voltmetre between C and E ? or between C and Grd ? and after C and Grd ?
what i am sure is the ouptut 13 is providing 5V.
I also changed the transistor it is the same
Your MM is dead, or something else is wrong.
Base to gnd (low output) shall result in no current through transistor, -> Uce = 5V (voltage from powersupply)
You drive base HIGH to allow current flow. The transistor shall saturate resulting in a voltage drop less then 0,5V, but NOT 0V
I'd check datasheet again. 5V to coil, other side of coil to Collector, Emitter to Gnd,
what is MM ?
multimeter (your voltmeter - set to DC)
with i hve HIGH 5v on output 13, i have 0,67 on the base
is it too much .?
yes my multimeter is set to DC and i can have 5V on output 13.
ok it 's working ... let me explain... don't laught please
i connected the 5V from arduino to Breadboard on the right side of the Breadboard
and i was using 5V to relay on the left side of the Breadboard , unfortunatly the left and right side are not connected !!!!
THANKS YOU VERY MUCH
..good to see. The ideal is to select R as big as possible, but small enough to bring transistor to saturate
U can see sat... by observing Uce < 0,5V ( 0.3..0,4 is perfect)
