Hello.
I want to send a value between 0 and 255 from processing to my arduino, I want to use this value to controll the brightness of a LED.
In processing I used the "serial.write" command to send the value.
In the arduino I used the "Serial.read" command to read the value.
Is this the right commands? Becuase I'dont get it to work.
himym:
Without any code, I wouldn't expect it to work. (Hint: Post your code)
This is the Processing code
import processing.serial.*;
Serial port;
int yValue = 318;
int midValue = 0;
int sendValue = 0;
size(600, 400);
port = new Serial(this, "COM6", 9600);
void draw() {
if (mousePressed && mouseX >= 102 && mouseX <= 158 && mouseY >= 82 && mouseY <= 318) {
yValue = mouseY;
//the int yValue gets the value of mouseY if the mouse is being pressed inside of the right area.
background(#18674B);
noStroke();
smooth();
fill(250);
ellipse(500, 350, 40, 40);
ellipse(535, 350, 40, 40);
fill(#18674B);
ellipse(500, 350, 28, 28);
ellipse(535, 350, 28, 28);
fill(250);
rectMode(CORNERS);
rect(495, 348, 505, 352);
rect(530, 348, 540, 352);
rect(533, 345, 537, 355);
//Arduino logotype
fill(0);
rectMode(CORNERS);
rect(100, 80, 160, 320);
//First rect(the black one)
fill(250);
rect(101, 81, 159, 319);
//Second rect(white)
fill(#D81F25);
rect(102, yValue, 158, 318);
//the red rect, you can change the size with the mouse
fill(250);
rect(102, 82, 158, yValue);
midValue = (600 - yValue - 282) * 255 / 236;
//instead of trying to map the yValue to a value between 0 and 255 you do a calculation
text(midValue, 180, 85);
port.write(midValue);
//send the midValue to the arduino
This is the arduino code
int ledPin = 9;
int dimmerValue = 0;
void setup(){
pinMode(ledPin, OUTPUT);
void loop(){
dimmerValue = Serial.read();
analogWrite(ledPin, dimmerValue);
Add this to the processing sketch. It will show the value of midvalue in the text window at the bottom of the processing IDE. It will help you look for the problem.
println(midValue);
Also, in your Arduino sketch, loop() runs very fast, and you are reading a value from the serial input every time through. Almost every time through, there will be nothing to read, and dimmerValue will contain the value -1, which you are then passing to analogWrite(). I haven't read the analogWrite() source, so I don't know what it does with a negative value. Try using Serial.available() to make sure there is something to read, before you read it.
Edit: It seems the source just passes the negative value on to the timer.
Now it's working thanx for the replys!
And if you give the "analogWrite" a -1, the Led is HIGH all the time.
