all i needed to do was send "OK" from vb to arduino and then arduino would start sending data and vb would receive it and display it
but not working...
here is the code i used
int ledPin = 13;
String usbnumber ;
String start = "OK";
pinMode(ledPin, OUTPUT);
if (Serial.available() >0)
usbnumber = Serial.read(); /*reading data*/
if (usbnumber == start ) /* cheching if vb sent "OK" start = "OK" */
Serial.println("1234567"); /*send 1234567 to vb*/
delay(10);
digitalWrite (ledPin,HIGH ); /* turn on led as indicator */
in vb side
[code]
Private Sub Command1_Click()
' Buffer to hold input string
Dim Instring As String
' Use COM3.
MSComm1.CommPort = 3
' 9600 baud, no parity, 8 data, and 1 stop bit.
MSComm1.Settings = "9600,N,8,1"
' Tell the control to read entire buffer when Input
' is used.
MSComm1.InputLen = 0
' Open the port.
MSComm1.PortOpen = True
Dim data As String
data = "OK"
MSComm1.Output = data
Dim readdata As String
readdata = MSComm1.Input
MsgBox readdata
MSComm1.PortOpen = False
End Sub
i had been messing around with the code for all day long and finally got one up and running
but still one problem
i transmit SEND in arduino
and receive say SEN one time S onetime SEND one time in vb
(pops up randomly)
the code is
Private Sub Form_Load()
' is used.
MSComm1.EOFEnable = True
MSComm1.RThreshold = 1
' Open the port.
End Sub
Private Sub MSComm1_OnComm()
Dim inbuffer() As Byte 'Declare an array of bytes
Dim b() As Byte
Dim i As Long
Dim s As String
Select Case Me.MSComm1.CommEvent
Case comEvReceive
ReDim inbuffer(Me.MSComm1.InBufferCount) 'Specify the size of the array. InBuffercount gives the number of characters in the InputBuffer
inbuffer = Me.MSComm1.Input 'Read the InputBuffer
For i = 1 To 20000
i = i + 1
Next i
For i = 0 To UBound(inbuffer) 'Ubound(inbuffer) gives the upper bound of the array, which is equal to the number of characters in the InputBuffer
Me.txtreceive.Text = Me.txtreceive.Text & Chr$(inbuffer(i)) 'TxtReceive is a text box
Next i
s = StrConv(inbuffer, vbUnicode)
End Select
MsgBox s
End Sub
i would like to send "y" in vb so that arduino would turn on led
but i dont know how arduino interprets the received "y" from vb
{note: i had confirmed that vb is sending string only using MSComm1.output="y" }
but my arduino is not interpreting it correctly please help
this is the code i used
int i;
char rec[7];
char str3 = "Y";
void establishContact();
// start serial port at 9600 bps:
Serial.flush();
pinMode(13, OUTPUT); // digital sensor is on digital pin 2
establishContact(); // send a byte to establish contact until receiver responds
// if we get a valid byte, read analog ins:
for (i=0;i<Serial.available();i++)
rec[i]=Serial.read();
delay(10);
if (rec==str3)
Serial.print("firs");
digitalWrite(13,HIGH);
//while (Serial.available() <= 0)
Serial.print("SEND");
//Serial.println(byte(26));
// send an initial string
delay(300);
str3 is a character, not a string. You should be using single quotes, not double quotes.
Suppose that initially there are 2 characters to read. On the first pass through the loop, i is 0, which is less than 2, so a character is read, and stored. Then, i is incremented to 1.
On the next pass through loop, Serial.available() returns 1, because one of the characters was read, and no more have arrived. 1 is not less than 1, so the loop ends.
delay(10);
Why?
if (rec==str3)
An array will never equal a character, no matter what is stored in the array or the character.
thanks a lot for all your help i finally got eberything lined up and working
i understood that serial.read returns bytes not integer and that to compare strings we need strcmp()
thanks
the code which FINALLY worked is
' is used.
MSComm1.RThreshold = 4 ' IMPORTANT change this to change the number of characters to be received
MSComm1.SThreshold = 3
' Open the port.
End Sub
Dim b() As Byte
Dim i As Long
Dim s As String
Case comEvReceive
Next i
End Select
MsgBox s
Dim string2 As String
string2 = "1234"
If StrComp(s, string2, vbTextCompare) = 0 Then
MsgBox s
MSComm1.Output = "YES"
End
Else
End If
End Sub
and in the arduino side
char inData[20]; // Allocate some space for the string
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
int ledpin =13;
Serial.flush();
pinMode(ledpin, OUTPUT); // digital sensor is on digital pin 2
while(Serial.available() > 0) // Don't read unless
// there you know there is data
//digitalWrite(ledpin,HIGH);
if(index < 19) // One less than the size of the array
inChar = Serial.read(); // Read a character
inData[index] = inChar; // Store it
index++; // Increment where to write next
inData[index] = '\0'; // Null terminate the string
if (strcmp(inData,"YES")==0)
Serial.print(inData);
// while (Serial.available() <= 0)
Serial.print("1234");
delay(300);
I am trying to do a similar thing with a robot i got from robot shop with the Arduino micro-controller and i want toy use VB 2010 to control it and give read outs from it's sensors to VB to be displayed on the screen. Do i need any special objects on the form or any special code in the arduino ,like firmata, or can i just write the code as you have it and accomplish the same thing?
Add a SerialPort object to your form then use functions like SerialPort1.Write() etc.
A simple VB.2008 example
Public Class Form1
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim i As Long
Dim s As String
If Not SerialPort1.IsOpen() Then
SerialPort1.Open()
End If
TextBox1.Text = ""
TextBox1.Refresh()
Do While i < 50
SerialPort1.Write("<hello>")
s = SerialPort1.ReadLine()
TextBox1.Text = TextBox1.Text + s + vbCrLf
TextBox1.Refresh()
i = i + 1
Loop
End Sub
Private Sub Form1_Disposed(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Disposed
If SerialPort1.IsOpen() Then
SerialPort1.Close()
End If
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
SerialPort1.PortName = "Com33"
SerialPort1.Open()
End Sub
End Class
Note that this is simple test code I used for a particular problem, your while loop will vary.
You've gotta reduce the size of that tiny graphic, it's over 3meg bytes, it took so long to load I was about to kill the page because I thought there was no content.
