Here's the code I am using. It's not complete yet, it doesn't drive the LCD or the earpiece, instead it prints the amplitude and phase to the serial port. I'm now using a MCP6283 op amp instead of the LM358 because it provides better gain at 8kHz. It also has a shutdown pin, which means I shouldn't need an on-off switch as I can put everything to sleep.
// Induction balance metal detector
// We run the CPU at 16MHz and the ADC clock at 1MHz. ADC resolution is reduced to 8 bits at this speed.
// Timer 1 is used to divide the system clock by 256 to produce a 62.5kHz square wave. This is used to drive timer 0 and also to trigger ADC conversions.
// Timer 0 is used to divide the output of timer 1 by 8, giving a 7812.5Hz signal for driving the transmit coil.
// This gives us 16 ADC clock cycles for each ADC conversion (it actually takes 13.5 cycles), and we take 8 samples per cycle of the coil drive voltage.
// Timer 2 is used to generate a tone for the earpiece or headset.
// Wiring:
// Connect digital pin 4 (alias T0) to digital pin 9
// Connect digital pin 5 through resistor to primary coil and tuning capacitor
// Connect output from receive amplifier to analog pin 0. Output of receive amplifier should be biased to about half of the analog reference.
// When using USB power, change analog reference to the 3.3V pin, because there is too much noise on the +5V rail to get good sensitivity.
#define TIMER1_TOP (255)
// Digital pin definitions
// Digital pin 0 not used, however if we are using the serial port for debugging then it's serial input
const int debugTxPin = 1; // transmit pin reserved for debugging
const int encoderButtonPin = 2; // encoder button, also IN0 for waking up from sleep mode
const int earpiecePin = 3; // earpiece, aka OCR2B for tone generation
const int T0InputPin = 4;
const int coilDrivePin = 5;
const int LcdRsPin = 6;
const int LcdEnPin = 7;
const int LcdPowerPin = 8; // LCD power and backlight enable
const int T0OutputPin = 9;
const int lcdD0Pin = 10;
const int lcdD1Pin = 11; // pins 11-13 also used for ICSP
const int LcdD2Pin = 12;
const int LcdD3Pin = 13;
// Analog pin definitions
const int receiverInputPin = 0;
const int encoderAPin = A1;
const int encoderBpin = A2;
// Analog pins 3-5 not used
// Variables used only by the ISR
int16_t bins[4]; // bins used to accumulate ADC readings, one for each of the 4 phases
uint16_t numSamples = 0;
const uint16_t numSamplesToAverage = 1024;
// Variables used by the ISR and outside it
volatile int16_t averages[4]; // when we've accumulated enough readings in the bins, the ISR copies them to here and starts again
volatile uint16_t ticks = 0; // system tick counter for timekeeping
volatile bool sampleReady = false; // indicates that the averages array has been updated
// Variables used only outside the ISR
int16_t calib[4]; // values (set during calibration) that we subtract from the averages
volatile uint8_t lastctr, lastMiss;
volatile uint16_t misses = 0;
const double halfRoot2 = sqrt(0.5);
const double quarterPi = 3.1415927/4.0;
const double radiansToDegrees = 180.0/3.1415927;
pinMode(encoderButtonPin, INPUT_PULLUP);
digitalWrite(T0OutputPin, LOW);
pinMode(T0OutputPin, OUTPUT); // pulse pin from timer 1 used to feed timer 0
digitalWrite(coilDrivePin, LOW);
pinMode(coilDrivePin, OUTPUT); // timer 0 output, square wave to drive transmit coil
cli();
// Set up timer 1.
// Prescaler = 1, phase correct PWM mode, TOP = ICR1A
TCCR1A = (1 << COM1A1) | (1 << WGM11);
TCCR1B = (1 << WGM12) | (1 << WGM13) | (1 << CS10); // CTC mode, prescaler = 1
TCCR1C = 0;
OCR1AH = (TIMER1_TOP/2 >> 8);
OCR1AL = (TIMER1_TOP/2 & 0xFF);
ICR1H = (TIMER1_TOP >> 8);
ICR1L = (TIMER1_TOP & 0xFF);
TCNT1H = 0;
TCNT1L = 0;
TIFR1 = 0x07; // clear any pending interrupt
TIMSK1 = (1 << TOIE1);
// Set up timer 0
// Clock source = T0, fast PWM mode, TOP (OCR0A) = 7, PWM output on OC0B
TIMSK0 = 0; // disable interrupt (was enabled by Arduino core)
TIFR0 = 0x07; // clear any pending interrupt
TCCR0A = (1 << COM0B1) | (1 << WGM01) | (1 << WGM00);
TCCR0B = (1 << CS00) | (1 << CS01) | (1 << CS02) | (1 << WGM02);
OCR0A = 7;
OCR0B = 3;
TCNT0 = 0;
// Set up ADC to trigger on timer 1 overflow, read channel 0
ADMUX = /*(1 << REFS0) | */ (1 << ADLAR); // Use Avcc as voltage reference, read channel 0, left-adjust result
ADCSRB = (1 << ADTS2) | (1 << ADTS1);
ADCSRA = (1 << ADEN) | (1 << ADSC) | (1 << ADATE) | (1 << ADIE) | (1 << ADPS2); // enable adc, free running, enable interrupt, prescaler = 16
DIDR0 = 1;
sei();
Serial.begin(19200);
ISR(TIMER1_OVF_vect)
++ticks;
// Interrupt service routine for ADC conversion complete
ISR(ADC_vect)
int16_t val = (int16_t)(uint16_t)ADCH; // only need to read most significant 8 bits
uint8_t ctr = TCNT0;
if (ctr != ((lastctr + 1) & 7))
++misses;
lastMiss = ctr;
lastctr = ctr;
int16_t *p = &bins[ctr & 3];
if (ctr < 4)
*p += (val);
if (*p > 15000) *p = 15000;
*p -= val;
if (*p < -15000) *p = -15000;
if (ctr == 7)
++numSamples;
if (numSamples == numSamplesToAverage)
numSamples = 0;
memcpy((void*)averages, bins, sizeof(averages));
memset(bins, 0, sizeof(bins));
sampleReady = true;
while (!sampleReady) {}
uint16_t oldTicks = ticks;
if (digitalRead(encoderButtonPin) == LOW)
for (int i = 0; i < 4; ++i)
calib[i] = averages[i];
Serial.print("Calibrated: ");
Serial.write(' ');
Serial.print(calib[i]);
Serial.println();
averages[i] -= calib[i];
const double f = 200.0;
double bin0 = (averages[0] + halfRoot2 * (averages[1] - averages[3]))/f;
double bin1 = (averages[1] + halfRoot2 * (averages[0] + averages[2]))/f;
double bin2 = (averages[2] + halfRoot2 * (averages[1] + averages[3]))/f;
double bin3 = (averages[3] + halfRoot2 * (averages[2] - averages[0]))/f;
double amp1 = sqrt((bin0 * bin0) + (bin2 * bin2));
double amp2 = sqrt((bin1 * bin1) + (bin3 * bin3));
double ampAverage = (amp1 + amp2)/2.0;
double phase1 = atan2(bin2, bin0) * radiansToDegrees - 45;
double phase2 = atan2(bin3, bin1) * radiansToDegrees;
if (phase1 > phase2)
double temp = phase1;
phase1 = phase2;
phase2 = temp;
double phaseAverage = (phase1 + phase2)/2.0;
if (phase2 - phase1 > 180.0)
if (phaseAverage < 0.0)
phaseAverage += 180.0;
phaseAverage -= 180.0;
//double diff =
//Serial.print(ticks);
//Serial.write(' ');
//Serial.print(numSamples);
if (bin0 >= 0.0) Serial.write(' ');
Serial.print(bin0, 2);
Serial.write(' ');
if (bin1 >= 0.0) Serial.write(' ');
Serial.print(bin1, 2);
Serial.write(' ');
if (bin2 >= 0.0) Serial.write(' ');
Serial.print(bin2, 2);
Serial.write(' ');
if (bin3 >= 0.0) Serial.write(' ');
Serial.print(bin3, 2);
Serial.print(" ");
Serial.print(amp1, 2);
Serial.write(' ');
Serial.print(amp2, 2);
Serial.write(' ');
if (phase1 >= 0.0) Serial.write(' ');
Serial.print(phase1, 2);
Serial.write(' ');
if (phase2 >= 0.0) Serial.write(' ');
Serial.print(phase2, 2);
Serial.print(" ");
if (ampAverage >= 0.0) Serial.write(' ');
Serial.print(ampAverage, 1);
Serial.write(' ');
if (phaseAverage >= 0.0) Serial.write(' ');
Serial.print((int)phaseAverage);
Serial.println();
//misses = 0;
while (ticks - oldTicks < 16000)
