First of all, thanks for all these info and this fantastic prototyping plateform.
I've just received my first Arduino UNO rev3, so i'm a newbie
i've check lot of pages but i didn't find the answer...
Sorry if the answer has already be given.
So, my question is :
If i connect my computer to Arduino through the USB cable and i plug at the same time an expernal power supply, do the board still take the AC from the xternal plug or does it take it from the USB ? (as Arduino Uno switch automaticaly)
I'm asking you because a red that there are some risk to destroy the USB port if we use too much electricity from it...
Board is designed to automatically switch between external and USB power.
If you connect external power supply to Vin pin or DC Jack, than the board will automatically isolate the USB power from board. If you look the Arduino UNO schematic than you can see how the switch is work.
Hi
Definitively, it' DC and not AC...
And basically, it won't be a wall supplier but a Li-Ion battery.
So, if i well understand, i just need to plug the - to the GND and + to the Vin, is it correct ?
I've a Arduino Uno Rev3.
My battery is this one (as i red, maybe the tension is too low ?!) : http://www.sgbotic.com/index.php?dispatch=products.view&product_id=216
Ok, definitively, this battery can't suit the arduino as it's is only 3,7v
Yes it's too low. As described here it should be 7-12VDC.
Yes, thanks.
Ok, i'm going to buy a new one.
As soon as I get it, to connect it to the UNO, the (-) to the GND pin and the (+) to the Vin ?! Is it correct ?
Even if I connect the board to my computer in USB, the electricity used by the board will be the one from the battery ? Is it correct ?
I guess you need the battery so your project can be portable, mains free? Becasue if not, an easier solution is a say 9 or 12VDC wall adapter thingy with a 2.1mm centre-positive connector for the round socket.
For long-term battery use, I'd solder a 2.1mm plug onto the battery leads instead of using the Vin and Gnd holes.
JimboZA:
Yes, i found a 12V DC Wall adapter with the correct connector. It's a 1A. I guess that this 1A suit good for the Arduino Uno
