Hi all,
I've got a digital inclinometer with +-0.1° accuracy. I'd like to get +-0.01° accuracy (an order of magnitude higher). I searched for commercial products, but couldn't find any.
So I looked here, and saw ADXL335 mentioned, as well as some other AD chips. Searching through AD's product selector I came across ADIS16203. I'm a bit confused about the accuracy of these chips...
Looking at ADIS16203 datasheet, I read "Linear output, 0.025° resolution" which would be ok, but on the next page I see:
Relative accuracy +-0.6°
Sensitivity 0.025°/LSB
Accuracy temp coeff +-0.0167°/°C
Output noise: no averaging 1.0°rms, max averaging 0.1°rms
My question is: supposing I put this chip into a tilt measurement instrument, could I say it would measure its tilt with a precision of +-0.025° ?
I've read on the AD site that by combining two ore more chips and averaging their readings one could improve accuracy because the noise curve is gaussian. I think this would be very challenging though, as it would require a very high precision while assembling the pcbs and other mechanical parts...
I've read some threads here about angle and position measuring. I'm starting to grasp the meaning of it all, but I'd like to have a hint about where to go for more information. Even a "can't be done" response would be helpful
PS: I'm not sure if this goes into "sensors" or "project guidance" section...
When you compensate the error in SW it is not so difficult, just be sure they are in a fixed position with respect to each other.
Then you put them in position 0°, read out the sensors and note their response.
repeat that for a number of angles e.g. every 5 degrees
Now you can average the delta's for the different sensors and correct for these offsets in your sketch.
IIRC the AD faq page said with n chips one can get improve by sqrt(n). Have to re-read it carefully to better understand what this means... How many adxl335 boards would I need to match one ADIS16203 ?
