Topic: The arduino stop storing data to SD card after 25 seconds, Please help (Read 295 times) previous topic - next topic
mehafelix
I am coding three CO2 sensors MG811. When running the code I noticed that the Arduino could not open the sd card and store data after 25 seconds of looping. Multiple try but same thing. Am I doing anything wrong??
Here is the code
Code: [Select]
#include <SD.h>
/************************Hardware Related Macros*********|***************************/
#define         MG_PIN                       (A0)     //define which analog input channel you are going to use
#define         BOOL_PIN                     (2)     //Arduino D2-CO2 sensor digital pinout, labled with "D" on PCB
#define         MG_PIN2                       (A1)     //define which analog input channel you are going to use for sensor 2
#define         BOOL_PIN2                     (5)     //Arduino D2-CO2 sensor digital pinout, labled with "D" on PCB  for sensor 2
#define         MG_PIN3                       (A2)     //define which analog input channel you are going to use for sensor 3
#define         BOOL_PIN3                     (6)     //Arduino D2-CO2 sensor digital pinout, labled with "D" on PCB for sensor 3
#define         DC_GAIN                      (8.5)   //define the DC gain of amplifier
/***********************Software Related Macros************************************/
#define         READ_SAMPLE_TIMES            (10)     //define how many samples you are going to take in normal operation
#define         READ_SAMPLE_INTERVAL         (50)    //define the time interval(in milisecond) between each samples in
//normal operation
/**********************Application Related Macros**********************************/
//These values differ from sensor to sensor. User should derermine this value.
#define         ZERO_POINT_X                 (2.602) //lg400=2.602, the start point_on X_axis of the curve
#define         ZERO_POINT_VOLTAGE           (0.324) //define the output of the sensor in volts when the concentration of CO2 is 400PPM
#define         MAX_POINT_VOLTAGE            (0.265) //define the output of the sensor in volts when the concentration of CO2 is 10,000PPM
#define         REACTION_VOLTGAE             (0.059) //define the €œvoltage drop€ of the sensor when move the sensor from air into 1000ppm CO2
/*****************************Globals***********************************************/
float           CO2Curve[3]  =  {ZERO_POINT_X, ZERO_POINT_VOLTAGE, (REACTION_VOLTGAE / (2.602 - 4))};
//Two points are taken from the curve.With these two points, a line is formed which is
//"approximately equivalent" to the original curve. You could use other methods to get more accurate slope
File MyFile;
//CO2 Curve format:{ x, y, slope};point1: (lg400=2.602, 0.324), point2: (lg10000=4, 0.265)
//slope = (y1-y2)(i.e.reaction voltage)/ x1-x2 = (0.324-0.265)/(log400 - log10000)
//**********************************************Void setup of code******************************************************************
  Serial.begin(9600);                              //UART setup, baudrate = 9600bps
  pinMode(BOOL_PIN, INPUT);                        //set pin to input
  digitalWrite(BOOL_PIN, HIGH);                    //turn on pullup resistors
  pinMode(BOOL_PIN2, INPUT);                        //set pin to input
  digitalWrite(BOOL_PIN2, HIGH);                    //turn on pullup resistors
  pinMode(BOOL_PIN3, INPUT);                        //set pin to input
  digitalWrite(BOOL_PIN3, HIGH);                   //turn on pullup resistors
  pinMode(8, OUTPUT);
  Serial.print("MG-811 Demostration\n");\
                                                    //Setting up the sd card for writing
  Serial.print("Initializing SD card...");
  if (!SD.begin(8)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  MyFile = SD.open("datafile.txt", FILE_WRITE);
  if (MyFile){
  MyFile.print( "volt1:");
  MyFile.print("\t\t\t\t");
  MyFile.print("Volt2");
  MyFile.print("Volts3");
  MyFile.print("C02(1):");
  MyFile.print("C02(2):");
  MyFile.print("C02(3):");
  MyFile.println("TIME:");
  MyFile.close();
//**********************************************************loop***********************************************************
 unsigned long currTime= (millis()/1000);
if (!MyFile) {
    Serial.println ("ERROR OPEN SD CARD, DATA WOULD NOT BE STOREED!!");
  int percentage1;
  int percentage2;
  int percentage3;
  float volts1;
  float volts2;
  float volts3;
  volts1 = MGRead(MG_PIN);
  volts2 = MGRead(MG_PIN2);
  volts3 = MGRead(MG_PIN3);
    //////////////////////////////////////////////////////// print to sd card sens01 : the code from the top is repeat by changing Serial to MyFile.
  if (MyFile) {
  MyFile.print(volts1);
  MyFile.print(volts2);
  MyFile.print(volts3);
  percentage1 = MGGetPercentage(volts1, CO2Curve);
  if (percentage1 == -1) {
    MyFile.print(" Heating/bey range(400~10,000) ");
    MyFile.print(percentage1);
   percentage2 = MGGetPercentage(volts2, CO2Curve);
  if (percentage2 == -1) {
    MyFile.print("heating/bey range(400~10,000) ");
    MyFile.print("                ");
    MyFile.print(percentage2);
 percentage3 = MGGetPercentage(volts3, CO2Curve);
  if (percentage3 == -1) {
    MyFile.print(" heating/bey range(400~10,000) ");
    MyFile.print(percentage3);
  MyFile.println(currTime);
  MyFile.close();
/*****************************  MQGetPercentage **********************************
  Input:   volts   - SEN-000007 output measured in volts
         pcurve  - pointer to the curve of the target gas
  Output:  ppm of the target gas
  Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
         of the line could be derived if y(MG-811 output) is provided. As it is a
         logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
         value.
int  MGGetPercentage(float volts1, float *pcurve) {
  volts1 = volts1 / DC_GAIN;
  if (volts1 > ZERO_POINT_VOLTAGE || volts1 < MAX_POINT_VOLTAGE ) {
    return -1;
    return pow(10, (volts1 - pcurve[1]) / pcurve[2] + pcurve[0]);
    volts1 = 0;
int  MGGetPercentage2(float volts2, float *pcurve) {
  volts2 = volts2 / DC_GAIN;
  if (volts2 > ZERO_POINT_VOLTAGE || volts2 < MAX_POINT_VOLTAGE ) {
    return -1;
    return pow(10, (volts2 - pcurve[1]) / pcurve[2] + pcurve[0]);
    volts2 = 0;
int  MGGetPercentage3(float volts3, float *pcurve) {
  volts3 = volts3 / DC_GAIN;
  if (volts3 > ZERO_POINT_VOLTAGE || volts3 < MAX_POINT_VOLTAGE ) {
    return -1;
    return pow(10, (volts3 - pcurve[1]) / pcurve[2] + pcurve[0]);
    volts3 = 0;
PaulS
Code: [Select]
if (!MyFile) {
  if (MyFile) {
Why are you opening the file twice without closing it in between?
mehafelix
