Topic: make values common in all menus (Read 610 times) previous topic - next topic
carlosfandango
Sep 12, 2017, 10:49 am Last Edit: Sep 14, 2017, 03:29 pm by carlosfandango Reason: new code update
Hello,
My project is an adjustable Voltage Sensing Relay working injunction with an LCD and buttons (the cheap copy of DFROBOT Shield).
I have 4 menus:
1: Home >  (voltage1 , voltage2 , current)       // displays the voltage1, voltage2 and current
2: Resting Voltage> (*********)      // Enter the "Resting Voltage" menu and it displays the
                                                    //restingVoltage and has an option to change the value
3: Running Voltage > (*********)     // Enter the " Running Voltage " menu and it displays the
                                                     //runningVoltage and has an option to change the value
4: Off Voltage > (*********)            //Enter the "Off Voltage" menu and it displays the offVoltage
                                                     //and has an option to change it
The problem is when I'm in Menu 2 ( or any other menu) and try to print the value of "voltage1" it errors and says "it's not declared in the scope"
My question is How can I make my code common to all the other menus?
I've attached my code, if you think you're able to help I would hugely appreciate it.
Thank you.
stowite
As far as I can see you have no variable called 'voltage' but you do have one called 'Voltage' . C and C++ are case sensitive.
groundFungus
Code: [Select]
float voltage1 = sensorValue1 * (50.00 / 1024); // resistor divider, 50volt max input / 1024
    int sensorValue2 = analogRead(A3); // sensorvalue2 is A2
    float voltage2 = sensorValue2 * (50.00 / 1024); // resistor divider, 50volt max input / 1024
You declare and assign values to the voltage1 and 2 variables in menuItem1() function.  Those values are only in scope in menuItem1().   Declare the varaibles in global scope and you can use them anywhere in the sketch.
carlosfandango
Thanks for the reply!
If I declare the variables in the global scope  that then the LCD doesn't print the voltage1, voltage2, or current.
Have I done the declaration right?
Code: [Select]
// code in global scope
int sensorValue1; // = analogRead(A2);
int sensorValue2; //= analogRead(A3); // sensorvalue2 is A3
PaulS
Quote
The declaration, yes. The initialization, no.
Use your delete key, not the // to stop executing code.
It does not make sense to multiply 0 by anything in the initialization of voltage1 and voltage2.
carlosfandango
PaulS - I'm really sorry I don't understand what you mean.
Please would you elaborate?
groundFungus
#6
Sep 12, 2017, 12:55 pm Last Edit: Sep 12, 2017, 01:00 pm by groundFungus
All that you need to do is declare the variables in global scope.  For instance:
Code: [Select]
float voltage1;
Then in the menuItem1() function, just remove the float type.
Code: [Select]
Code: [Select]
All variables declared in global scope are automatically assigned the value of 0 if not otherwise initialized.  So sensorValue1 and sensorValue2 = 0 and so sensorValue? * (50.00 / 1024 =  0 * (50 / 1024) = 0.
PaulS
Quote
You have one statement to declare and initialize a variable:
Code: [Select]
The comment is pointless, since the variable has nothing to do with a resistor divider. So, the code is actually:
Code: [Select]
Now, since sensorValue1 was declared, but NOT initialized, two lines above this one, the compiler did the initialization for you, so this code is really:
Code: [Select]
float voltage1 = 0 * (50.00 / 1024);
Now, everyone knows that 0 times anything is 0, so why not just have
Code: [Select]
float voltage1 = 0.0;
and look like you know what you are doing?
carlosfandango
PaulS - Sorry, the comments were because I copied and pasted from another location, I should have removed that to save confusion.
Code: [Select]
Code: [Select]
Code: [Select]
Code: [Select]
PaulS - Mainly because I don't know what I'm doing - I'm learning.
Thanks a lot groundFungus - your comments really helped and I've achieved what I wanted.
carlosfandango
Can someone explain why in a menu3 (or any menu), the code doesn't "loop" and so it refreshes the value of voltage1? I've tried a good few different ways but with the same outcome.
Code: [Select]
// Running Voltage Menu
void menuItem3() {
  // Function executes when you select the 3rd item from main menu
   int activeButton = 0;
   lcd.clear();
 do {
      int sensorValue1 = analogRead(A2);
  lcd.setCursor(0,0);
  lcd.print("VOLT LIVE");
  lcd.setCursor (11,0);
  lcd.print(voltage1);
  menuState3=true;
  int button;
    readKey = analogRead(0);
    if (readKey < 790) {
      delay(100);
      menuState3=false;
   } while (menuState3==true);
while (activeButton == 0) {
    int button;
      delay(100);
    button = evaluateButton(readKey);
    switch (button) {
      case 4:  // This case will execute if the "back" button is pressed
        button = 0;
        activeButton = 1;
I feel like maybe I should try to make my own menu , the problem is I can't find anything online that shows how to do anything similar to what I'm doing? If you know of something that I may find useful please let me know! Thanks
UKHeliBob
Code: [Select]
      int button;
      if (readKey < 790)
        delay(100);
      switch (button)
          button = 0;
          activeButton = 1;
Have you tried printing the values of activeButton  and button ?
Why use switch/case when there is only one case ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
carlosfandango
Hello UKHeliBob,
If I print the values of activeButton  and button, they come back as 0.
I'm using switch/case as it was part of the code I downloaded.
basically I wrote the code to do what I want the device to do, but I wanted to add an LCD and be able to change values within my code via buttons... I didn't know where to start and as I couldn't find any similar projects online, I used a code template and am trying to integrate my code into it... which isn't going to well!
UKHeliBob
If activeButton is always zero then the while.loop will never end
It is time to investigate why its value does my change
carlosfandango
Thanks UKHeliBob, your comment helped me look for a solution. This seems to work...
It's only taken me 12 hours. This project still isn't even close to finished. I think I may have started something I'm unable to finish due to my lack of knowledge.
Code: [Select]
void menuItem3() {
  int button;
  lcd.clear();
  lcd.setCursor(0,0);
  menuState3=true;
  while(menuState3==true){
      delay(100);
    switch (button) {
        button = 0;
        activeButton = 1;
        menuState3=false;
carlosfandango
Is there a way to return a value to global scope?
for instance I have
Code: [Select]
float restingVoltage = 13.0;
float runningVoltage = 13.7;
float offVoltage = 14.3;
and in my " resting Voltage Menu" I want to change the "float resting Voltage " in the global scope.
Code: [Select]
  lcd.setCursor (10,0);
  lcd.setCursor (10,1);
  lcd.print(restingVoltage);
  analogRead(0);
  if(readKey <195){
    restingVoltage = 13.5 ;
    else if
    (readKey <380) {
      restingVoltage = 13.4;
