pour le moment j'essaie de faire tourner le montage avec la syntaxe du Midi drumKit dans sa version initiale. je n'utilise pas les boutons j'utilise seulement un piezo.
mon montage Piezo(zener et Resistance) dans entrée anal 0 et un femelle midi(resistance) sur numérique 1 en sortie reliée à mon mac via une interface Midi/usb.
je n'utilise pas de module, ni de soft de zick...
- MIDI Drum Kit
- Convert Arduino to a MIDI controller using various inputs and
- the serial port as a MIDI output.
- This sketch is set up to send General MIDI (GM) drum notes
- on MIDI channel 1, but it can be easily reconfigured for other
- notes and channels
- It uses switch inputs to send MIDI notes of a fixed velocity with
- note on time determined by duration of keypress and it uses
- piezo buzzer elements as inputs to send MIDI notes of a varying velocity
- & duration, depending on forced of impulse imparted to piezo sensor.
- To send MIDI, attach a MIDI out jack (female DIN-5) to Arduino.
- DIN-5 pinout is: _____
- pin 2 - Gnd / \
- pin 4 - 220 ohm resistor to +5V | 3 1 | MIDI jack
- pin 5 - Arduino D1 (TX) | 5 4 |
- all other pins - unconnected _2_/
- On my midi jack, the color of the wires for the pins are:
- 3 = n/c
- 5 = black (blue)
- 2 = red (red)
- 4 = orange (yellow)
- 1 = brown
- Based off of Tom Igoe's work at:
- http://itp.nyu.edu/physcomp/Labs/MIDIOutput
- Created 25 October 2006
- copyleft 2006 Tod E. Kurt <tod@todbot.com
http://todbot.com/
// what midi channel we're sending on
#define drumchan 1
// general midi drum notes
#define note_bassdrum 35
#define note_snaredrum 38
#define note_hihatclosed 42
#define note_hihatopen 44
#define note_crash 49
// define the pins we use
#define switchAPin 7
#define switchBPin 6
#define switchCPin 5
#define piezoAPin 0
#define piezoBPin 1
#define ledPin 13 // for midi out status
// analog threshold for piezo sensing
#define PIEZOTHRESHOLD 100
int switchAState = LOW;
int switchBState = LOW;
int switchCState = LOW;
int currentSwitchState = LOW;
int val,t;
pinMode(switchAPin, INPUT);
pinMode(switchBPin, INPUT);
pinMode(switchCPin, INPUT);
digitalWrite(switchAPin, HIGH); // turn on internal pullup
digitalWrite(switchBPin, HIGH); // turn on internal pullup
digitalWrite(switchCPin, HIGH); // turn on internal pullup
pinMode(ledPin, OUTPUT);
Serial.begin(31250); // set MIDI baud rate
// deal with switchA
currentSwitchState = digitalRead(switchAPin);
if( currentSwitchState == LOW && switchAState == HIGH ) // push
noteOn(drumchan, note_bassdrum, 100);
if( currentSwitchState == HIGH && switchAState == LOW ) // release
noteOff(drumchan, note_bassdrum, 0);
switchAState = currentSwitchState;
// deal with switchB
currentSwitchState = digitalRead(switchBPin);
if( currentSwitchState == LOW && switchBState == HIGH ) // push
noteOn(drumchan, note_snaredrum, 100);
if( currentSwitchState == HIGH && switchBState == LOW ) // release
noteOff(drumchan, note_snaredrum, 0);
switchBState = currentSwitchState;
// deal with switchC
currentSwitchState = digitalRead(switchCPin);
if( currentSwitchState == LOW && switchCState == HIGH ) // push
noteOn(drumchan, note_hihatclosed, 100);
if( currentSwitchState == HIGH && switchCState == LOW ) // release
noteOff(drumchan, note_hihatclosed, 0);
switchCState = currentSwitchState;
// deal with first piezo, this is kind of a hack
val = analogRead(piezoAPin);
if( val >= PIEZOTHRESHOLD ) {
t=0;
while(analogRead(piezoAPin) >= PIEZOTHRESHOLD/2) {
t++;
noteOn(1,note_hihatopen, t*2);
delay(t);
noteOff(1,note_hihatopen,0);
// deal with second piezos, this is kind of a hack
val = analogRead(piezoBPin);
t=0;
while(analogRead(piezoBPin) >= PIEZOTHRESHOLD/2) {
t++;
noteOn(1,note_crash, t*2);
delay(t);
noteOff(1,note_crash,0);
// Send a MIDI note-on message. Like pressing a piano key
void noteOn(byte channel, byte note, byte velocity) {
midiMsg( (0x80 | (channel<<4)), note, velocity);
// Send a MIDI note-off message. Like releasing a piano key
void noteOff(byte channel, byte note, byte velocity) {
// Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2) {
digitalWrite(ledPin,HIGH); // indicate we're sending MIDI data
Serial.print(cmd, BYTE);
Serial.print(data1, BYTE);
Serial.print(data2, BYTE);
digitalWrite(ledPin,LOW);
