Hello!
I've had my Uno R3 for a couple of weeks. Everything was going fine and then I think I accidentally sent 12V into the wrong pin(s).
So I've spent a few hours trying to figure out just which part is broken and whether the board is salvageable. It's pretty clear to me that I need help from this beneficent forum.
BTW, first post
Some data points:
- When I plug the board in to my mac, the usb device appears
- The green "on" led comes on. The orange L1 led comes on (the one on digital out 13).
- The reset button has no effect
- The orange led doesn't behave the way it used to. On power-on it stays steady rather than flashing for a little while before remaining steady.
- I can't upload sketches. I get: "avrdude: stk500_recv(): programmer is not responding"
- I can use the serial monitor to send text to the Uno and the RX light flashes but the TX light doesn't flash
- I tried the loopback test by connecting pins 0 and 1 (TX & RX) and RESET and GND and powering on the Uno. The text comes back to me as expected. So it looks like the 16u2 is working
- Just to be sure, I put the 16u2 into DFU mode and reflashed it with dfu-programmer (which I had to patch to support the atmega16u2) and that went fine
- On the chance that it's the atmega328p that's not working, I bought a replacement. I couldn't get a atmega328p right away (I'll have to order one online) but I did get an atmega8 which I inserted (the right way around).
I can't burn the bootloader. I've tried "Arduino Uno" and "Arduino NG or older w/ATmega8" but they both give the same result:
/Users/jeremy/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Users/jeremy/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega8 -cstk500v1 -P/dev/tty.usbmodemfa131 -e -Ulock:w:0x3F:m -Uhfuse:w:0xca:m -Ulfuse:w:0xdf:m
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/jeremy/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/jeremy/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodemfa131
Using Programmer : stk500v1
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
"/dev/tty.usbmodemfa131" is the correct device and I can see the RX light flash. The TX light doesn't flash.
I'm out of ideas. Except getting another board!
Any thoughts?
Cheers,
Jeremy
By the way, I'm in Sydney Australia so, while I'm pretty motivated to fix my Uno (or at least diagnose it), I may not reply right away if it's the middle of the night here
