Solution for short pin value changes due reset and on/off Arduino Micro
Hi Everyone!
Need your help!
There are 4 pulse mode devices which should properly work with Arduino Micro.
Devices are very stupid and has no any configuration. one pulse between 5-65 ms and it take a command.
Got a problem when I restart or turn on my Arduino Micro.
I get junk command to my pulse devices just Immediately after reset or turn it on. (Arduino).
All PinModes installed proper so I think it is some boot load pin check which switch pins before IDE program loads.
I have no ideas how to solve this in soft way. Some friends suggest hardware solution to make trimer before loading...
Any ideas to solve this first boot contact bounce in a time matter? 1-3 seconds will enough.
Many thanks for any help!
same topic for the reason "installation solution": Help - short pin value changes due reset and on/off Arduino Micro - - Installation & Troubleshooting - Arduino Forum
sorry for double. really need to solve it quick.
Let's see your code.
read this before posting a programming question
