hey guys,
I'm a 15 years old student who is working on a research project about arduino and i'm having a problem and i was wondering if you lads could help me. My project is a servo conected to an ultrasonic sensor, it would work like a radar, the servo works on its own and so the sesor but when i mix them ithey don't. The monitor serial instead of showing me the distance between the sensor and the object it tells me its angle.
I dont know how to change that, here's the code, will you guys check it please? As you will see most of the code is copied from the internet. By the way sorry if my english ain't understandable, i'm not native speaker. Thanks!
HC-SR04 Ping distance sensor:
VCC to arduino 5v
GND to arduino GND
Echo to Arduino pin 7
Trig to Arduino pin 8
This sketch originates from Virtualmix: http://goo.gl/kJ8Gl
Has been modified by Winkle ink here: Winkleink - box of wires: Arduino - HC-SR04 ultrasonic distance sensor
And modified further by ScottC here: http://arduinobasics.blogspot.com.au/2012/11/arduinobasics-hc-sr04-ultrasonic-sensor.html
on 10 Nov 2012.
#include <Servo.h>
Servo miServo;
int angulo=90;
#define echoPin 7 // Echo Pin
#define trigPin 8 // Trigger Pin
#define LEDPin 13 // Onboard LED
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration;
float distance; // Duration used to calculate distance
miServo.attach(9);
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(LEDPin, OUTPUT); // Use LED indicator (if required)
unsigned char comando=0;
if(Serial.available()){
comando=Serial.read();
if(comando=='a')angulo+=10;
else if(comando=='z')angulo-=10;
angulo=constrain(angulo,0,180)
miServo.write(angulo);
Serial.print("Angulo:");Serial.println(angulo);
delay(100);
/* The following trigPin/echoPin cycle is used to determine the
distance of the nearest object by bouncing soundwaves off of it. */
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
if (distance >= maximumRange || distance <= minimumRange){
/* Send a negative number to computer and Turn LED ON
to indicate "out of range" /
Serial.println("-1");
digitalWrite(LEDPin, HIGH);
else {
/ Send the distance to the computer using Serial protocol, and
turn LED OFF to indicate successful reading. */
Serial.println(distance);
digitalWrite(LEDPin, LOW);
//Delay 50ms before next reading.
