The theater chase from tweaking4all seems to be like this :
- One LED of each N LEDs (meaning the other N-1 are off)
- Shift every LEDs by one to the right: do the shift N-1 times (due to periodicity)
(I hope I explain clearly, I'm not native english speaker)
This can be done by playing with modulo (the % operator)
void setLEDs (int K,int N) {
for (int i=0;i<NUM_LEDS;i++) {
if (i%N == K) leds[i].setRGB (127, 0, 0); // set red LED
This function should be called in the loop :
FastLED.clear();
for (int i=0;i<N;i++) {
setLEDs (i,N); }
FastLED.show();
delay (50);
The setup changes to
delay (1000);
LEDS.addLeds<LED_TYPE, LED_DT, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setBrightness(max_bright);
and you need to declare the period before the setup:
N = 5;
for example.
Try it !
