Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 360551 times) previous topic - next topic
JimInWoodstock
I am used to a dark theme when coding. I also am new to the plugin and eclipse. I have been using the Arduino IDE in the past. I installed the Moonrise UI and it shows up in the installed plugin list. However, when I go to windows, appearance I don't see the moonrise UI theme. In general, how to I get this to work and how do I find other dark themes that might be available?
Problem solved. Read the docs more carefully.
Jantje
Great :-)
Another problem solved.
Thanks for reporting success
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
nbarbet
Good morning, I have trouble building a shared Arduino project with Google Drive using Eclipse with the plug-in for Arduino. I created an empty Arduino project in Eclipse environment of PC and imported to the folder with the real Arduino project present in Google Drive, but I can not connect this project in Eclipse ... I would to share the project of Google Drive on two platforms (Mac and PC) Each one with Eclipse installed ... at the moment I can modify the project "shared" with Eclipse and then compile with Arduino compiler, but I can not with the Eclipse compiler ... thanks, Nicola
Jantje
@nbarbet
I don't think that will work as the .project and .cproject are OS dependent.
Why don't you use a version control system like github. That works great if you checkin a initial .project and .cproject and then add those to the .ignore file
Arrowmax
Jantje, Could you please share printscreens of your settings for the Arduino Zero in Sloeber?
Your youtube video describes how to debug the ESP8266, but I get an error using OpenOCD with Arduino Zero: No source available for "0xfffffffe"
Jantje
I do not have print screens. I also can not make printscreens/videos of my work as I don't us the zero.
Actually I'm hardly doing any arduino work right now. Most of it is maintaining sloeber.
Making a zero debugging video on my todo list but so is 4.0 new and noteworthy :-(
Best regards
Jantje
darthbolek
Linux Fedora 25 64-bit install tips.
1. for serial access add user to groups: lock, dialout
sudo usermod -a -G lock <user>
sudo usermod -a -G dialout <user>
2. avrdude is missing libtinfo.so.5 library. The green color and line "upload done" is a little misleading... I'd expect red and "failure" :)
arduinoPlugin/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude: error while loading shared libraries: libtinfo.so.5: cannot open shared object file: No such file or directory
avrdude finished
upload done
In F25 there is version 6 only. Adding link 5 -> 6 solves avrdude runtime problem. It might have impact on stability of avrdude and/or other software.
sudo ln -s /lib64/libtinfo.so.6.0 /lib64/libtinfo.so.5
Code: [Select]
[xxx@yyy sloeber]$ ldd arduinoPlugin/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude
 linux-vdso.so.1 (0x00007ffc5b0c7000)
 librt.so.1 => /lib64/librt.so.1 (0x00007f5e00f2e000)
 libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f5e00d10000)
 libm.so.6 => /lib64/libm.so.6 (0x00007f5e00a07000)
 libtinfo.so.5 => not found
 libc.so.6 => /lib64/libc.so.6 (0x00007f5e00641000)
 /lib64/ld-linux-x86-64.so.2 (0x000055b879390000)
xxx@yyy sloeber]$ ls -l /usr/lib64/libtinfo*
lrwxrwxrwx. 1 root root     15 Jul 19  2016 /usr/lib64/libtinfo.so.6 -> libtinfo.so.6.0
-rwxr-xr-x. 1 root root 180200 Jul 19  2016 /usr/lib64/libtinfo.so.6.0
[xxx@yyy sloeber]$ sudo ln -s /lib64/libtinfo.so.6.0 /lib64/libtinfo.so.5
[xxx@yyy sloeber]$ ls -l /usr/lib64/libtinfo*
lrwxrwxrwx  1 root root     22 Feb 28 12:51 /usr/lib64/libtinfo.so.5 -> /lib64/libtinfo.so.6.0
After these my Sloeber is programming boards now.
Jantje
@darthbolek
Thanks for fixing your problems yourself and thanks for sharing :-)
Jantje
lafleur
I just installed Sloeber and it looks great...
But when I try to compile my project, the IDE 1.8.0 reference to processor type do NOT appear in Sloeber..
Like:
__SAMD21G18A__
ARDUINO_ARCH_SAMD
ARDUINO_ARCH_AVR
did I miss something during the install??
thanks
Jantje
JimInWoodstock
I have a sketch that I developed in the arduino ide. I want to migrate this to the sloeber ide and discontinue using the rather primitive arduino ide. However, I get quite a few errors regarding the included libraries. I am attaching a zip file containing the code and the errors. Please take a look and let me know what I did wrong.
Thanks
Jantje
My hourly rate is 100 euro exclusive VAT.  8)
How much time do you want me to spend on this?  :smiley-evil:
pito
Installed Sloeber today, the V4. Updated via nighty.
When trying to install the j-link plugin from your http://eclipse.baeyens.it/update/V4/nightly I get:
Code: [Select]
Cannot complete the install because of a conflicting dependency.
  Software being installed: GNU ARM C/C++ J-Link Debugging 4.1.1.201606210758 (ilg.gnuarmeclipse.debug.gdbjtag.jlink.feature.group 4.1.1.201606210758)
  Software currently installed: Sloeber, the Eclipse Arduino IDE 4.0.0.201701171403 (io.sloeber.product 4.0.0.201701171403)
  Only one of the following can be installed at once:
    GNU ARM C/C++ Debugger Restart Button 1.3.1.201606210758 (ilg.gnuarmeclipse.debug.gdbjtag.restart 1.3.1.201606210758)
    GNU ARM C/C++ Debugger Restart Button 1.3.1.201701170259 (ilg.gnuarmeclipse.debug.gdbjtag.restart 1.3.1.201701170259)
  Cannot satisfy dependency:
    From: GNU ARM C/C++ J-Link Debugging 4.1.1.201606210758 (ilg.gnuarmeclipse.debug.gdbjtag.jlink.feature.group 4.1.1.201606210758)
    To: ilg.gnuarmeclipse.debug.gdbjtag.restart [1.3.1.201606210758]
    From: GNU ARM C/C++ OpenOCD Debugging 4.1.2.201701170259 (ilg.gnuarmeclipse.debug.gdbjtag.openocd.feature.group 4.1.2.201701170259)
    To: ilg.gnuarmeclipse.debug.gdbjtag.restart [1.3.1.201701170259]
    From: Sloeber, the Eclipse Arduino IDE 4.0.0.201701171403 (io.sloeber.product 4.0.0.201701171403)
    To: ilg.gnuarmeclipse.debug.gdbjtag.openocd.feature.group [4.1.2.201701170259]
Any hint how to get segger into debug configurations?
Jantje
This issue has been discussed here https://github.com/Sloeber/arduino-eclipse-plugin/issues/665
I havn't been able to dive into why this problem exists but it is related to part of gnuarmeclipse being in the plugin for debugging.
pito
J-link plugin issue - The nightly built from April 1st has done it (win7 64b here)..
