buongiorno
sto cercando di utilizzare questo display con questo codice
#define CS 13 //Pin 13 as chip selection output
#define WR 12 //Pin 12 as read clock output
#define DATA 7 //Pin 7 as Serial data output
#define CS1 digitalWrite(CS, HIGH)
#define CS0 digitalWrite(CS, LOW)
#define WR1 digitalWrite(WR, HIGH)
#define WR0 digitalWrite(WR, LOW)
#define DATA1 digitalWrite(DATA, HIGH)
#define DATA0 digitalWrite(DATA, LOW)
#define sbi(x, y) (x |= (1 << y))
#define cbi(x, y) (x &= ~(1 <<y ))
#define uchar unsigned char
#define uint unsigned int
//定义HT1621的命令
#define ComMode 0x52 //4COM,1/3bias 1000 010 1001 0
#define RCosc 0x30 //1000 0011 0000
#define LCD_on 0x06 /1000 0000 0 11 0
#define LCD_off 0x04
#define Sys_en 0x02 //1000 0000 0010
#define CTRl_cmd 0x80
#define Data_cmd 0xa0
/*0,1,2,3,4,5,6,7,8,9,A,b,C,c,d,E,F,H,h,L,n,N,o,P,r,t,U,-, ,*/
const char num[]={0x7D,0x60,0x3E,0x7A,0x63,0x5B,0x5F,0x70,0x7F,0x7B,0x77,0x4F,0x1D,0x0E,0x6E,0x1F,0x17,0x67,0x47,0x0D,0x46,0x75,0x37,0x06,0x0F,0x6D,0x02,0x00,};
//0 1 2 3 4 5 6 7 8 9
char dispnum[6]={0x00,0x00,0x00,0x00,0x00,0x00};
void SendBit_1621(uchar sdata,uchar cnt)
//data cnt HT1621
uchar i;
for(i=0;i<cnt;i++)
WR0;
if(sdata&0x80) DATA1;
else DATA0;
WR1;
sdata<<=1;
void SendCmd_1621(uchar command)
CS0;
SendBit_1621(0x80,4);
SendBit_1621(command,8);
CS1;
void Write_1621(uchar addr,uchar sdata)
addr<<=2;
CS0;
SendBit_1621(0xa0,3);
SendBit_1621(addr,6);
SendBit_1621(sdata,8);
CS1;
void HT1621_all_off(uchar num)
uchar i;
uchar addr=0;
for(i=0;i<num;i++)
Write_1621(addr,0x00);
addr+=2;
void HT1621_all_on(uchar num)
uchar i;
uchar addr=0;
for(i=0;i<num;i++)
Write_1621(addr,0xff);
addr+=2;
void Init_1621(void)
SendCmd_1621(Sys_en);
SendCmd_1621(RCosc);
SendCmd_1621(ComMode);
SendCmd_1621(LCD_on);
void displaydata(int p)
uchar i=0;
switch(p)
case 1:
sbi(dispnum[0],7);
case 2:
sbi(dispnum[1],7);
case 3:
sbi(dispnum[2],7);
default:break;
for(i=0;i<=5;i++)
Write_1621(i*2,dispnum[i]);
pinMode(CS, OUTPUT); //
pinMode(WR, OUTPUT); //
pinMode(DATA, OUTPUT); //
CS1;
DATA1;
WR1;
delay(50);
Init_1621();
HT1621_all_on(16); //1621
HT1621_all_off(16); //1621
displaydata(1);//light on the first decimal point starting from the right side
dispnum[5]=num[5];
dispnum[4]=num[4];
dispnum[3]=num[3];
dispnum[2]=num[2];
dispnum[1]=num[1];
dispnum[0]=num[0];
sbi(dispnum[5],7);
//cbi(dispnum[5],7);
sbi(dispnum[4],7);
//cbi(dispnum[4],7);
sbi(dispnum[3],7);
//cbi(dispnum[3],7);
//Write_1621(0,num[0]);
//Write_1621(2,num[28]);
//Write_1621(4,num[2]);
//Write_1621(6,num[28]);
//Write_1621(8,num[4]);
//Write_1621(10,num[5]);
// you can place your main code here to run repeatedly
con la funzione Write_1621(,num[]) riesco a visualizzare una cifra in una determinata posizione
vorrei visualizzare una variabile long e credo che la funzione da utilizzare sia displaydata(1); ma non capisco dove passare come argomento la mia variabile..
idee?
grazie
