Topic: NeoGPS - configurable, ultra-small RAM footprint (Read 26777 times) previous topic - next topic
-dev
Both NeoGPS and TinyGPS just need to be fed bytes.  The example programs all use Serial and SoftwareSerial, though.
You should be able to do the same thing with SPI as a source of bytes.  It should be something like
  spi.begin();
  while (something) {
    in_byte = spi.transfer( 0xFF );
    gps.decode( in_byte );
  spi.end();
According to the ublox spec, section 4.4, 0xFF will be returned by the spi.transfer when there are no more available bytes.  Although the decode methods will correctly ignore the 0xFF bytes, you probably want to watch for them so you can do something else.  For TinyGPS, you will have to watch for consecutive 0xFF bytes:
  uint8_t FF_bytes = 0;
  spi.begin();
  while (FF_bytes < 50) {
    if (in_byte == 0xFF)
      FF_bytes++;
      FF_bytes = 0;
  spi.end();
  // Do something else
For NeoGPS, you can watch for a different return code:
  spi.begin();
  do {
  } while (gps.decode(byte) != NMEAGPS::DECODE_CHR_INVALID);
  spi.end();
This is just for reading bytes.  If you need to write bytes (like a configuration command or a poll), you'll do the same kind of thing... the output bytes are written out by the same transfer method:
  spi.begin();
  while (something) {
    spi.transfer( out_byte );
  spi.end();
What complicates this process is that the Neo-6 can send a byte back at the same time, if it has something.  You have to continue decoding during a write:
  spi.begin();
  while (something) {
    in_byte = spi.transfer( out_byte );
  spi.end();
That's the basic idea, I think.  You'll have to fill a lot blanks!  :)  Keep us posted.
Cheers,
/dev
Really, I used to be /dev.  :(
rockeronline00
Thank you for your code! Nice job  8)
I just realized that many Ublox neo 6m boards don't implement SPI wires..  They only have VCC, GND, TX, RX .
 :smiley-confuse:
I think I need to find the correct output wires from the main processor and solder some custom wires
MS in Computer Science
Drones addicted
Musician and composer
-dev
A recent discussion revealed that some GPS devices may report a message like "GNRMC" instead of the common "GPRMC".  This led me down the rabbit hole of NMEA quasi-baz-standard... Oy!
It turns out that the first two characters are called the Talker ID.  In this case, a GPS device was reporting "GPRMC" when only GPS satellites were used to calculate a fix, and "GNRMC" when a mix of GPS and GLONASS satellites were used.  Furthermore, it could report "GLRMC" if only GLONASS satellites were used.
This variation also appears in the GSV sentences: GLGSV reports GLONASS satellite info, and GPGSV reports GPS satellite info.  There are other Talker IDs, as well: GA (Galileo) and GB (BeiDou).
To accommodate these devices, I have updated NeoGPS to parse, save or skip the Talker ID.
While messing with this part of the parser, I also noticed that proprietary messages (those beginning with "$P") are also supposed to have a 3-character Manufacturer ID.  For the ublox devices, these are the "$PUBX" messages.  NeoGPS will now parse, save or skip the Mfr ID as well.
Suprisingly, this change increased speed by about 10%.  It also eliminated the need to store the "GP" Talker ID, or any other talker ID, reducing the program space.  In fact, ublox devices do not even have a proprietary message table.  The first integer field after "$PUBX," identifies the proprietary message type: 0 or 4.
Woot.
/dev
-dev
One more iteration of squeezing better performance out of NeoGPS:
Configuration    Sentence    NeoGPS    TinyGPS    Performance
Improvement
MinimalGGA
RMC
436us
485us
   -70%
66%
DTLGGA
RMC
839us
859us
   -42%
40%
NominalGGA
RMC
913us
936us
1448us
1435us
37%
35%
Full1GGA
RMC
1094us
1075us
   -25%
25%
At less than 1ms to parse a sentence, that's about 0.1% CPU utilization, when the sentences are received once per second.  Even with 10Hz updates, that's only 1% CPU utilization per sentence!
Cheers,
/dev
1  While the Full configuration is "only" 25% faster than TinyGPS, it handles more message types and fields.  This configuration should probably be compared with TinyGPS++; the improvement would be much higher, as well as using 900 bytes less RAM.
-dev
A few updates:
  • A configuration error was fixed, which caused a compile error.   :-[
  • Now supports Unos and other non-Mega boards.  See NMEA.INO, other examples to be updated Real Soon Now.
  • Installation section is much more detailed.
  • Troubleshooting section includes general GPS device tips for connecting, baud rate and signal reception, as well as tips for resolving configuration errors.
  • Example configurations now include a Full configuration (everything!)
  • Example sketch shows how to convert UTC time to local time using a time zone offset, including partial hour time zones.  See NMEA.INO
I hope this makes NeoGPS more accessible.  Looking under the hood may still be scary, but pre-defined configurations and Board-specific serial selection should make it usable by most programmers "out of the box".
If anyone has suggestions, especially for improving the documentation, I'd greatly appreciate it.
Cheers,
/dev
-dev
Updates:
  • Added explicit statements regarding GLONASS, BeiDou and Galileo support.
  • Extended the Troubleshooting section to include images and descriptions of the all-to-common input overflow (aka "trying to do too much").
  • Added a new section that shows which NMEA messages fill out which parts of a gps_fix.  This helps immensely when Choosing Your Configuration.
Cheers,
/dev
-dev
Updates:
  • Added diagnostic program to auto-detect baud rate: NMEAdiagnostic
  • Added diagnostic program to display list of sentences emitted by your GPS device: NMEAorder
  • Increased quiet time window by 5ms or more by immediately keying off of last sentence in 1-second interval
  • Added test cases to NMEAtest
  • Added recommend sequence of programs to try
  • Updated docs, including comment blocks at top of each .INO
Cheers,
/dev
-dev
Updates:
  • Increased performance by 3%.  A special-purpose divide routine decreased the lat/lon parse time by 25us.
  • Increased precision by using the minute's 6th digit after the decimal point.  Overall significant digits for integer lat/lon is now about 10.  For example, 117.0969485° longitude is parsed from 117° 5.816909".  Integer form is 1170969485, parsed from NMEA field "11705.816909".
  • Fixed truncation error when longitude >= 128°.  Test case added.
Cheers,
/dev
-dev
Updates:
  • Added an interrupt-driven example that uses the new NeoHWSerial replacement for HardwareSerial.  The example registers a procedure to be called during the received character interrupt.
  • Worked around an IDE limitation on nested includes.  Caused a "SoftwareSerial.h" not found on UNO platforms.
  • Added diagnostic messages to NMEA.ino to help the user determine that the baud rate is incorrect or that the sentence order is different from what was expected (different GPS devices have different sentence orders).
Cheers,
/dev
-dev
Updates:
  • All examples can now use NeoHWSerial, NeoICSerial or NeoSWSerial, in addition to the typical SoftwareSerial and AltSoftSerial.  By simply including one of those headers, the example programs will use that library for the GPS device.
  • This allows all Arduino boards to use an interrupt-driven technique, as shown in the NMEA_isr.INO example.
With this collection of serial drivers, I'd like to think the vast majority of Arduino boards and GPS device configurations are covered by the NeoGPS examples.
Cheers,
/dev
eric_marsh
I'm working on a project that will require a GPS fusion with other instruments to overcome MEMS gyro drift in a fixed wing aircraft. Cheap is good and small is good. So at this point I'm using a Teensy 3.x and one of these GPS units that only has i2c. Since the processor is already too close to being saturated and TinyGPS++ is losing characters I decided that what I really need is to be able to program the GPS to get what I need, when I need it and nothing else. That seems to mean sending UBX commands.
After digging around I found neoGPS. It's quite the impressive project but at this point it won't build for me, throwing errors about being unable to find a serial port.
When I get home I'll look things over some more. But before I get too far into things are there any major obstacles (such as only having an I2c interface) controlling the NEO-6 with your library and the Teensy? At this point I'm just coming up to speed on the GPS hardware interfaces in general, thought I have worked with the iOS GPS libraries.
 :smiley-confuse:
-dev
Quote
Well, you might be ok sticking with NMEA if you turn off all sentences and then poll for the ones you want.  You could even send some UBX binary configuration commands.  Next, you could try polling for the more-compact PUBX NMEA messages instead of the typical GGA+RMC combo.  If you still need more time or fewer interrupts, then I'd switch to the UBX binary protocol.
Quote
I've never built for the Teensy 3.0, but at least one other user has tried compiling NeoGPS on a 32-bit platform.  I made a few changes related to its 32-bit quirks vs. the 8-bit AVRs.
The examples all try to pick a serial port, based on which Arduino you're using.  I don't think it knows what to do for your build.  Just delete the include of GPSport.h, and declare your own gps_port variable for it to use... assuming you have one for testing?
If you're using I2C in a polling style at this point, you'll need to modify the polling examples' loop to feed bytes to NeoGPS:
Code: [Select]
static void GPSloop()
  while ( I2C_data_available() ) {
    if (gps.decode( I2C_read_byte() ) == NMEAGPS::DECODE_COMPLETED) {
If you're using I2C in an interrupt style, you'll need to modify the NMEAfused_isr.ino example to hook it to your interrupt and pass it the byte:
Code: [Select]
static void GPSisr( uint8_t c )  // called when I2C has a byte?
  if (gps.decode( c ) == NMEAGPS::DECODE_COMPLETED) {
Quote
LOL, I don't know what I don't know.  32-bit vs 8-bit should be the biggest thing.  If you can get the I2C bytes and pass them to NeoGPS' decode function, it won't care where they came from.
There could be some effort in getting the UBX protocol working over I2C.  I think there's some Serial-specific timing related to the ACKs that are supposed to come back when you send configuration commands.  And there's a sequence of steps you have to perform before you can even use the UBX POSNAV and VELNED messages.
I'd really suggest trying an optimized NMEA approach first.  You may find the increased efficiency of NeoGPS is all you need.  For the typical GGA+RMC, NeoGPS uses just 1.7ms vs 2.9ms per update (on a 20MHz AVR), nearly twice as fast.  If you only need lat/lon/alt (not date/time/satellites/hdop), it's even faster.
So far, its seems that the biggest problem for new users is understanding when they need a safe copy of "the current fix".  Understanding how new pieces of a fix should be merged as they are received is also important.  If you're using the interrupt style, then gps.fix() could change at any time.  You will have to double-buffer it.
Picking a custom configuration can also be tricky, but there is some compile-time assistance for invalid configurations.
Cheers,
/dev
enters
Hi /dev,
thank you for your GPS library!
Also a really great documentation and examples that helped me understanding it.
But I have one question:
Is there a chance that you are going to implement a data member for the geoid-height field of the GGA-message?
Greetings,
enters
-dev
Quote
Yes.  All done!    :)
Cheers,
/dev
enters
