Topic: Wireless programming of an arduino with HC-05 bluetooth module (Read 11831 times) previous topic - next topic
guix
Setting AT+POLAR=1,0 will make the STATE pin LOW when connected ;)
MikeLemon
Yes but what id I still want to use the BL module as a wireless communication device after programming without moving anything?
guix
Yes, no need to move anything, it will work as if it was a usb cable :)
If you want to disable auto reset of your arduino every time you open the serial monitor, I posted a solution here (and you may be interested by the last post :) )
MikeLemon
Yes but every time you connect to the module and use just to transfer data(Not to upload a sketch) I'd reset the arduino and what I want is to have the PC send a sequences of commands to active a certain pin on the other HC-05 module to reset the arduino on the receiving side and then start programming it so after wards you can still use the other side to transmit or receive data.
mrteddycox
Can wireless programming be down with a BLE module like HM-10?
