Topic: Topic: Problem sending a HTTP POST (Read 194 times) previous topic - next topic
JaqueCaamal
I am trying to send data to an HTTP page but I get a watchdog error.
Code: [Select]
#include <ESP8266WiFi.h>
const char* ssid = "---"; // Enter SSID here
const char* password = "---"; // Enter Password here
char server[] = "requestb.in";
String PostData = "Hello World";
WiFiClient client;
  Serial.println("Connecting to ");
  Serial.println(ssid);
  //connect to your local wi-fi network
  WiFi.begin(ssid, password);
  //check wi-fi is connected to wi-fi network
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
   if (client.connect(server, 80)) {
    // Make a HTTP request:
    Serial.println("connected");
  client.println("POST /1ip84q91 HTTP/1.1");
  client.println("Host:  requestb.in");
  client.println("User-Agent: Arduino/1.0");
  client.println("Connection: close");
  client.println("Content-Type: application/x-www-form-urlencoded");
  client.print("Content-Length: ");
  client.println(PostData.length());
  client.println();
  client.println(PostData);
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    while (true);
It connects to the network but doesn't do the POST, what am I doing wrong? Thank you.
I'm using
Arduino IDE 1.6.4
NodeMCU with ESP8266
This is a test to be able to integrate it into a code that I am working on.
PaulS
Code: [Select]
    while (true);
Well, that will certainly trigger a watchdog exception.
Move your post code into setup(). Leave loop() empty. Do NOT try to stop loop() from looping.
pylon
Quote
How do you know that? Have you seen the server log? I'd guess that it produces an error on the server because you say that the content is of type 'application/x-www-form-urlencoded' but what you send isn't in that format.
Does that WiFi network has internet access?
JaqueCaamal
Yes, I'm sorry. That's what I was trying to say. Yes it has internet access.
pylon
Did you read the rest of my answer?
