In the hardwired connections I just have respected the pins identityes and connect with the corresponding arduino layout.
The only software change in pinout has been to swap the chipselect pins.
Thanks again.
Mario.
Very strange! Two things come to mind as a possible cause:
- There is a short (or open) circuit (perhaps intermittent) that is interfering with the signal lines, this could be on the LCD PCB or in the wiring.
- The LCD is not able to respond to the timings provided by the library code.
I don't think its timing because the datasheet timings appear to be standard ks0108 values that have worked on other boards. That said, it may be that your board is overly fussy about timing. You can try to slow the library down by adding some extra delay in the delay450ns function in the ks0108.cpp file, but I would be surprised if that fixed it (but happy for you if it did). Don't forget to delete the ks0108.o file after a change:
static void delay450ns(void){ // delay 450 nanoseconds
asm volatile("nop\n\t"
"nop\n\t" // add these two more nops to slow things down a little
"nop\n\t"
"nop\n\t"
"nop\n\t"
"nop\n\t"
"nop\n\t"
Not sure what else to suggest, other than have a look a what happens when the pixel rate is slowed right down. You do that by uncommenting the following line in ks0108.cpp
//#define GLCD_DEBUG // uncomment this if you want to slow down drawing to see how pixels are set
You should then see each vertical block of up to 8 pixels being drawn. Perhaps a video of that may tell us more.
You may also want to modify your test so there is a fixed black rectangle somewhere on the screen so we can see if any of these are erased at random. Try this without clearing the screen on every write ( move your call to clearscreen in the if(m> 64) block and change n++ to n = n + 32, change m++ to M + = 12;
...If the number of "nop\n\t" increase your surprise, prepare for this...
To remove all little dots and leave the original example inside the library runing clearly, I have had to add 26. :o
The FPS are 6 and works perfect.
I appreciate very much your help and now I can keep on programming on mi project.
If I can help somehow to add this lcd module in the arduino playground for example, please let me know as I would collaborate gladly. I prefer you to do it after you find an explanation about what has happened with the signals timming in this model.
Thanks for everything,
Mario.
I am very happy you got it going and am surprised that your LCD needs such a long delay. Adding 26 nops makes the delay around 2 microseconds, the spec sheet says it that 450ns should be sufficient.
Anyway, I wonder if you can test some code that I could add to the library that would make it easier to support panels that need a long delay.
Could you comment out all the nops that you added and instead replace the code in the Enable function in ks0108.cpp with the following :
#define XTREME_ENABLE_DELAY 4
__inline__ void ks0108::Enable(void) {
fastWriteHigh(EN); // EN high level width: min. 450ns
delay450ns();
fastWriteLow(EN);
#ifdef XTREME_ENABLE_DELAY
for(volatile uint8_t i=0; i< XTREME_ENABLE_DELAY; i++);
#else
delay450ns();
#endif
You may need to increase the value of XTREME__ENABLE_DELAY from 4 to 5 or perhaps even 6, but if a value of 8 isnt' enough then I will suggest a slightly different place to add the delay.
Keep me posted.
Hello Mem,
I have made the changes in the .c file as you suggested, the delay seems not to be placed in the right position. The text is not working properly again even with the variable set to 10.
I have returned to the previous "26 nops" version.
Tell me what else we can do.
Regards,
Mario.
Ok, lets put the Enable(void) method back the way it was and increase the generic delay. This will do the same things as your added nops but uses less code, and it can be easily enabled or disabled if I put it into the distributed file.
#define BIG_DELAY 4 // uncomment this to increase the delay to by a few microseconds
#ifdef BIG_DELAY
for(volatile uint8_t i=0; i< BIG_DELAY ; i++);
#else
"nop\n\t"
"nop\n\t"
"nop\n\t" "nop\n\t"
#endif
First post - so here goes. Firstly many thank mem for a great library - my project would not be possible without this.
I have a very similar problem to Mario_B so thought I would chip in my findings.
I am using a KS0108B based 128x64 lcd from Sure Electronics
(type B pinout ). Bought from ebay - cheap as chips IF it can be made to work OK.
I had to add 48 (yes count them!) nop instructions to get a steady display at which point my FPS count is 5.
Like Mario_B using XTREME_ENABLE_DELAY method did not work even when using large values (e.g. 200)
Using the BIG_DELAY method works a treat and I can decrease BIG_DELAY to 1 - at which point my FPS is 5.
Other thoughts/advice needed-
Is an FPS of 5 likely to impact my project - ie should I look for a better lcd before proceeding?
Could my wiring be too long. I'm running on a solderless breadboard currently and the wires between arduino and lcd are about 5 inches long.
Similar problem (with a different lcd) reported in sparkfun forum
A responder thinks that this might be due to "reflections" and that "terminating with a couple of 50 ohm resistors might help". I can try this out if someone can tell me in detail how to wire this up.
Thanks
(had included links to sparkfun and sure electronics but system wont allow me to post these in first post )
If helpful sure electronics spec (minimal )here
http://www.sure-electronics.net/mcu,display/DE-LM112_Ver1.0_EN.pdf
Sparkfun post here
http://forum.sparkfun.com/viewtopic.php?p=54266&sid=8780ce9c9529416bb23df535091842b5
Hi Rower, thanks for the information. It is possible that very long cable lengths could be an issue, but I use 5 inch long wires and mine works great, so I think it unlikely that is the problem. Anyway, don't use 50 ohm resistors, that will put much too much load on the arduino pins.
I think I may have a CFAG12864B LCD buried away somewhere here, if that is the same as yours I will try it and see if I also need the big delay.
Running with an FPS of 5 is not a problem if your sketch runs fast enough.
I found the GLCD panal I got from Sure electronics a while ago but it's not the same as Rower's (mine is a type 'A' Crystalfontz panel), so I am no clearer on why some of the type 'B' panels need extra delays.
For those reading this thread looking to decide which panel to get, I think the type 'A' panels (+v on pin 1, data0 on pin4 etc) have been easier to integrate then type 'B' panels.
I wonder if there would be much interest if I offered to supply a full performance ready to run 128x64 GLCD panel that included wired connectors and the little PCB with contrast and backlight resistors
I think I could probably do them for around $20 plus shipping if there was enough interest. PM me if you want one (don't post here, lets keep this thread to technical discussions)
Arduino not included
Hello Mem,
Your last proposed delay450ns(void) function works overally well but I want to make the following remarks:
-The BIG_DELAY definition can be lowered down to 1 and it still works.
-The frames per second is decreased from 6 to 5 comparing this version with the "26 nops" version. It Seems it can be fine tuned better adding nops.
That is all I have found.
Thanks,
Mario.
Mem,
Found my LCD washing my clothes this week in a pair of pants, lucky i did check my pockets before washing. Allways check your pockets before washing, never know what you can find ;D .
So after my PopDuino creation today i continued with connecting the LCD.
So i have updated my H-file to this:
#define CSEL1 31 // CS1 Bit // swap pin assignments with CSEL2 if left/right image is reversed
#define CSEL2 30 // CS2 Bit
#define R_W 29 // R/W Bit
#define D_I 28 // D/I Bit
#define EN 37 // EN Bit
/* Arduino pins used for LCD Data
* un-comment ONE of the following pin options that corresponds to the wiring of data bits 0-3
//#define dataPins8to11 // bits 0-3 assigned to arduino pins 8-11, bits 4-7 assigned to arduino pins 4-7
//#define dataPins14to17 //bits 0-3 assigned to arduino pins 14-17, bits 4-7 assigned to arduino pins 4-7. (note command pins must be changed)
#define dataPins0to3 // bits 0-3 assigned to arduino pins 0-3 , bits 4-7 assigned to arduino pins 4-7, this is marginally the fastest option but its only available on runtime board without hardware rs232.
Using digital pins 0-7 and analog pins 0-4 that are supposed to be pins 31-27. But no luck, wrong pin assignment by me?
http://sanguino.cc/useit
Could it be the sanguino code that is missing nedeed code to complete the task?
http://code.google.com/p/sanguino/downloads/list
Hi Hulk,
The mapping of pins to ports won't work for pin numbers that are different than the arduino. Also, arduino digital pin numbers are not the same as the chips pin numbers.
When I can find some time I will look at the chip you are using and post some macros for you. But it would be easier of you can connect the LCD using the pins that correspond to the standard arduino pins.
Morning Mem,
Was reading your post about the ATMega 644 and the arduino compatibillity.
So i guess i will not be able to change around pins using the existing Atmel ATmega specification?
Or could i use the PC, PD, PB pin indications as referance?
Or should i use ADC0... for analog and T0, T1, AINO, AIN1, ICP, OC1, SS, MOSI for digital.
By the way the updated Ks0108 Library compiles with out problems with my Arduino 0012 software and Windows XP, just having problems viewing the update on the LCD ;D
Did you try it on the ATMega 644 using the default pins (the pins as defined in the library header file)? If that works then perhaps you could use the extra pins on the chip for your other interfaces. If the standard arduino pins as defined in the header don't work or it's not convenient to use the other pins for your other interfaces, I would question the sanguino folks about the claimed compatibility with the arduino.
If the issue is sanguino compatibility with arduino code, lets move this discussion to another thread where others more experienced in this area can contribute. I don't have an ATMega 644 and have no direct experience with it so am not in a good position to help.
Mem,
I did connect the LCD Ks0108 pinout type B to the ATMega 644 as follows:
Digital pins 0-7 and analog pins 0-4 to pins 31-27 and therefore i updated the header to:
#define EN 27 // EN Bit
Using digital pins 8-11 would be a problem due to tx and rx being pin 8 and 9.
But what you are saying is that if i try it may work? Should i keep the analog pins 27-31 or use the default 18-15?
So the code should be exactlly:
#define CSEL1 15 // CS1 Bit // swap pin assignments with CSEL2 if left/right image is reversed
#define CSEL2 14 // CS2 Bit
#define R_W 16 // R/W Bit
#define D_I 17 // D/I Bit
#define EN 18 // EN Bit
//#define dataPins0to3 // bits 0-3 assigned to arduino pins 0-3 , bits 4-7 assigned to arduino pins 4-7, this is marginally the fastest option but its only available on runtime board without hardware rs232.
I think i need to make sure that it is not me that is doing something wrong before posting the sanguino compatibility...
Using digital pins 8-11 would be a problem due to tx and rx being pin 8 and 9...
I think the sanguino guys are much better positioned to answer your question than me, I really have no idea how to map pins on the ATMega 644 chip for use with arduino software.
I hope the following helps you phrase your questions to them:
A specific question is: given that this arduino library uses thirteen of the twenty arduino defined digital pins, eight accessed through direct port io, five through arduino digital pin mappings, should this code work unchanged on the sanguino, if not, where can guidelines be found for running arduino code to the sanguino
This question expressed more generally is:
What are the issues with arduino software (such as different mappings to ports and/or resources) using digital pins 0-19 on the ATmega644, either with digitalWrite or using direct port access?
As I mentioned above, I think this discussion is better placed in a thread on sanguino and/or ATmega644 compatibility. I will be happy to post any conclusions here that relate to the GLCD library, but the issue you raise is how to get a chip that claims arduino compatibility working with arduino code, and I think this is an interesting and potentially involved discussion that doesn't belong in a thread dedicated to the Graphics LCD library.
I think the sanguino guys are much better positioned to answer your question than me, I really have no idea how to map pins on the ATMega 644 chip for use with arduino software.I hope the following helps you phrase your questions to them:
What are the issues with arduino software (such as different mappings to ports and/or resources) using digital pins 0-19 on the ATmega644, either with digitalWrite or using direct port access?As I mentioned above, I think this discussion is better placed in a thread on sanguino and/or ATmega644 compatibility. I will be happy to post any conclusions here that relate to the GLCD library, but the issue you raise is how to get a chip that claims arduino compatibility working with arduino code, and I think this is an interesting and potentially involved discussion that doesn't belong in a thread dedicated to the Graphics LCD library.
Moved this issue to:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1223141170/0#0
Here is an updated version of the ks0108.cpp file for those that want to play with modifying the timing delays for displays that can't handle the 450ns updates.
I am making some other changes to the library to make it compatible with other chips, like the ATmega644 and will wait until this is completed before updating the playground code. I would appreciate if anyone that has had trouble with slow displays could try this code and see if it fixes the problem.
The delays can be tweeked by changing some constants added at the beginning of the file.
#define DELAY_EN_ON 10 // tweek these two to optimize speed
#define DELAY_EN_OFF 10
#define DELAY_RD_ON 2 // these two probably don't need tweeking for any display
#define DELAY_RD_OFF 2
The values above work on my 'slow' LCD, my fast LCD works with all constants equal to 2
Don't forget you need to delete the .o file before each recompile
There isn't room for the entire file here so I have removed all the methods at the start of the file. You will need to past these back if you want to test this code,
Here is the fragment:
// ks0108.cpp fragment
// the following four defines determine delays on the enable pin
// values as below work on my slowest display, my fastest works with all values of 2
// 2 is around 0.5us, 4 = 1us, 8 = 2us 10= 2.5us
#define DELAY_RD_ON 2 // these two may not need tweeking for any display
#include "ks0108.h"
extern "C" {
#include <inttypes.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <wiring.h> // added 18 Sept 2008 for Arduino release 0012
// all methods before delay450ns have been removed here to fit the post.
// You need to past these in here from you existing file
"nop\n\t"
"nop\n\t"
"nop\n\t" // todo, remove some nops if clock is less than 16mhz
"nop\n\t"
fastWriteHigh(EN); // EN high level width min 450 ns
asm volatile( "ldi r24, %0 \n\t"
"subi r24, 0x1 \n\t"
"and r24, r24 \n\t"
"brne .-6 \n\t"
::"M" (DELAY_EN_ON) :
"r24" );
// delay450ns();
fastWriteLow(EN);
"and r24, r24 \n\t"
"brne .-6 \n\t"
::"M" (DELAY_EN_OFF) :
"r24" );
// delay450ns();
uint8_t ks0108::DoReadData(uint8_t first) {
uint8_t data;
lcdDataOut(0x00);
lcdDataDir(0x00); // data port is input
if(this->Coord.x < CHIP_WIDTH) {
fastWriteLow(CSEL2); // deselect chip 2
fastWriteHigh(CSEL1); // select chip 1
else if(this->Coord.x >= CHIP_WIDTH) {
fastWriteLow(CSEL1); // deselect chip 1
fastWriteHigh(CSEL2); // select chip 2
if(this->Coord.x == CHIP_WIDTH && first) { // chip2 X-address = 0
this->WriteCommand(LCD_SET_ADD, CHIP2); // wuff wuff
fastWriteHigh(D_I); // D/I = 1
fastWriteHigh(R_W); // R/W = 1
"and r24, r24 \n\t"
"brne .-6 \n\t"
::"M" (DELAY_RD_ON) :
"r24" );
// delay450ns();
#ifdef LCD_DATA_NIBBLES
data = (LCD_DATA_IN_LOW & 0x0F) | (LCD_DATA_IN_HIGH & 0xF0);
#else
data = LCD_DATA_IN_LOW; // low and high nibbles on same port so read all 8 bits at once
#endif
fastWriteLow(EN);
"and r24, r24 \n\t"
"brne .-6 \n\t"
::"M" (DELAY_RD_OFF) :
"r24" );
// delay450ns();
lcdDataDir(0xFF);
this->GotoXY(this->Coord.x, this->Coord.y);
if(this->Inverted)
data = ~data;
return data;
inline uint8_t ks0108::ReadData(void) {
this->DoReadData(1); // dummy read
return this->DoReadData(0); // "real" read
void ks0108::WriteCommand(uint8_t cmd, uint8_t chip) {
if(chip == CHIP1) {
else if(chip == CHIP2) {
fastWriteLow(D_I); // D/I = 0
fastWriteLow(R_W); // R/W = 0
lcdDataDir(0xFF);
lcdDataOut(cmd);
this->Enable(); // enable
lcdDataOut(0x00);
void ks0108::WriteData(uint8_t data) {
uint8_t displayData, yOffset;
#ifdef LCD_CMD_PORT
uint8_t cmdPort;
#endif
#ifdef GLCD_DEBUG
volatile uint16_t i;
for(i=0; i<5000; i++);
#endif
if(this->Coord.x >= DISPLAY_WIDTH)
return;
else {
lcdDataDir(0xFF); // data port is output
yOffset = this->Coord.y%8;
if(yOffset != 0) {
// first page
#ifdef LCD_CMD_PORT
cmdPort = LCD_CMD_PORT; // save command port
#endif
displayData = this->ReadData();
#ifdef LCD_CMD_PORT
LCD_CMD_PORT = cmdPort; // restore command port
#else
else {
#endif
displayData |= data << yOffset;
if(this->Inverted)
displayData = ~displayData;
lcdDataOut( displayData); // write data
// second page
this->GotoXY(this->Coord.x, this->Coord.y+8);
#ifdef LCD_CMD_PORT
#else
else {
#endif
displayData |= data >> (8-yOffset);
if(this->Inverted)
lcdDataOut(displayData); // write data
this->GotoXY(this->Coord.x+1, this->Coord.y-8);
else {
if(this->Inverted)
data = ~data;
lcdDataOut(data); // write data
this->Coord.x++;
lcdDataOut(0x00);
// class wrapper
ks0108::ks0108(){
this->Inverted=0;
// Make one instance for the user
ks0108 GLCD = ks0108();
Mem,
I will check during the weekend and give you feedback.
