I have posted some code containing "[" "i" "]" as variable index.
The forum seems to ignore this specific sequence of 3 caracters and I wonder why...
In the folowing on line 10, my code is:
Flag"[" "i" "]" = true;
And it become:
Flag = true;
This append when doing "copy for forum" and also when doing normal copy and paste.
Any idéa?
//Interrupt Service Routine On Timer Overflow
ISR(TIMER2_OVF_vect) {
for (int i=0; i<ChannelNbr; i++){
//Increment Overflow Counter
T2_OverFlow*++;* if (T2_OverFlow > 25) { * //Fail Safe Value* PulseLenght = FailSafeVa*;* * //Set Flag* _ Flag = true; * } } }*_
I tried to modifie my post using normal copy and past between codes tags.
But even when using code tags as you propose the quoted i [ i ] does not go through...
Quoted j [j] does but quoted [ i ] does not! (quote/space/i/space/quote in purpose to make it visible)
Look at this:
Quoted j [j] between code tags:
[j]
Quoted i [ i ] between code tags:
[/quote] Grrrrrr....(Is my bloody Azerty key pad driving me crazy?) Thanks for help. Length, length, length (I get it now).
Not a good feeling but I have to admit "the crazy frog" is also stupid...
I did not get right the diff between quote tags and code tags!
Now I think my post is clean.
Thank again for the bad feeling you gave me.
