Ive now moved all the pins to their correct positions and I can read its address and whatever else it spits out. could i have help with decoding what it gives me over the serial port? here is the code
#include <OneWire.h>
// DS18S20 Temperature chip i/o
OneWire ds(10); // on pin 10
void setup(void) {
// initialize inputs/outputs
// start serial port
void loop(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
Serial.print("No more addresses.\n");
ds.reset_search();
return;
Serial.print("R=");
for( i = 0; i < 8; i++) {
Serial.print(addr[i], HEX);
Serial.print(" ");
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
if ( addr[0] == 0x10) {
Serial.print("Device is a DS18S20 family device.\n");
else if ( addr[0] == 0x28) {
Serial.print("Device is a DS18B20 family device.\n");
else {
Serial.print("Device family is not recognized: 0x");
Serial.println(addr[0],HEX);
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print("P=");
Serial.print(present,HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print( OneWire::crc8( data, 8), HEX);
Serial.println();
this is what it gives me over serial:
P=1 30 0 4B 46 FF FF A 10 47 CRC=47
No more addresses.
R=10 95 5F D 2 8 0 FF Device is a DS18S20 family device.
the values seem to change so I am wondering if somewhere in there the temperature is imbedded in it.
